I get an error setting the PPI interface via the adi_ppi driver
Question asked by rgd@dvt on Jul 11, 2016
Latest reply on Jul 18, 2016 by Jithul_Janardhanan
Problem with debugging EPPI:
I wrote my own part for using the PPI driver to set it up. The green marked line below jumps to the  adi_eppi_setFSMode (little further below. I tried all kind of things with the handle (therefore it looks a bit strange now), but all give the same result. The line with pDevice = (ADI_EPPI *) hDevice; inadi_eppi_setFSMode results in the value 0x00000080 for pDevice. This is also the value of hDevice.
My function looks like:
static ADI_EPPI_RESULT ConfigPPI(OV4682_INFO *pDevInfo)
        uint32_t                nHPeriod;   /* Horizontal period */
        uint32_t                nVPeriod;   /* Vertical Period */
        ADI_EPPI_HANDLE *hHandle;
        /*ADI_EPPI_HANDLE **/hHandle = pDevInfo->hPPIDevice;
        OV4682_FRAME_INFO *pFrameInfo;// = malloc(sizeof(OV4682_FRAME_INFO)); /* Pointer to frame information */
        pFrameInfo = &pDevInfo->oFrameInfo; /* Pointer to frame information */
    do
if(adi_eppi_SetFSMode(hHandle , ADI_EPPI_FS_MODE2) != ADI_EPPI_SUCCESS)break; //( hHandle, ADI_EPPI_FS_MODE2)                                                     /* Set the frame sync mode (1, 2, or 3 frame syncs) */
        if(adi_eppi_SetITUMode(hHandle, ADI_EPPI_GENERAL_PURPOSE) != ADI_EPPI_SUCCESS)break;                                             /* Set transfer mode to Non ITU mode (2 or 3 frame syncs) */
if(adi_eppi_SetFSPolarity(pDevInfo->hPPIDevice, ADI_EPPI_FS1HI_FS2HI) != ADI_EPPI_SUCCESS)break;                                                  /* Set frame sync polarity (Active high) */
if(adi_eppi_SetDataLength(pDevInfo->hPPIDevice, ADI_EPPI_16BIT) != ADI_EPPI_SUCCESS)break;                                                               /* Set the data length */
        if(adi_eppi_SetDmaTransferSize(pDevInfo->hPPIDevice,(ADI_EPPI_DMA_TRANSFER_SIZE) pDevInfo->eDMATxSize) != ADI_EPPI_SUCCESS)break;/* Set the DMA transfer size */
if(adi_eppi_SetClkPolarity(pDevInfo->hPPIDevice, ADI_EPPI_RISECLK_RISEFS ) != ADI_EPPI_SUCCESS)break;                                           /* Set Frame sync and clock polarity */
if(adi_eppi_SetHorizontalDelay(pDevInfo->hPPIDevice, OV4682_HPULSE_WIDTH) != ADI_EPPI_SUCCESS)break;                                           /* Set horizontal delay (number of clock cycles to delay after assertion of FS1 before transmitting data)  */
if(adi_eppi_SetVerticalDelay(pDevInfo->hPPIDevice,0u) != ADI_EPPI_SUCCESS)break;        /* Set vertical delay (Delay in terms of number of lines to wait before transmitting the data) */
        if(adi_eppi_SetLinesPerFrame( pDevInfo->hPPIDevice, pFrameInfo->nLinesPerFrame ) != ADI_EPPI_SUCCESS)break;                              /* Set lines per frame (including horizontal front and back porch) */
        if(adi_eppi_SetVerticalCount(pDevInfo->hPPIDevice,pFrameInfo->nLinesPerFrame) != ADI_EPPI_SUCCESS)break;                                     /* Set number of active lines per frame */
if(adi_eppi_SetSamplesPerLine(pDevInfo->hPPIDevice,((pFrameInfo->nPixelsPerLine + pFrameInfo->nHBlanking) * OV4682_BYTES_PER_PIXEL)) != ADI_EPPI_SUCCESS)break; /* Set number of pixels per line */
if(adi_eppi_SetHorizontalCount( pDevInfo->hPPIDevice,(pFrameInfo->nPixelsPerLine * OV4682_BYTES_PER_PIXEL) ) != ADI_EPPI_SUCCESS)break;/* Set number of pixels per line */
if(adi_eppi_SetPack( pDevInfo->hPPIDevice, true ) != ADI_EPPI_SUCCESS)break;        /* Enable packing mode */
        if(adi_eppi_StreamingEnable(pDevInfo->hPPIDevice, true) != ADI_EPPI_SUCCESS)        /* Enable streaming DMA mode */
if(adi_eppi_RepetiveBufferEnable(pDevInfo->hPPIDevice, true) != ADI_EPPI_SUCCESS)break;        /* Enable frame repeat mode for video */
return ADI_EPPI_SUCCESS; /* All the APIs are successful return success */
} while(0);
       return ADI_EPPI_FAILURE;
// this is from adi_ppi_bf6xx.c
ADI_EPPI_RESULT adi_eppi_SetFSMode(ADI_EPPI_HANDLE const hDevice, ADI_EPPI_FS_MODE eFsMode)
    /* assume a return code */
    ADI_EPPI_RESULT Result = ADI_EPPI_SUCCESS;
    /* EPPI Device */
    ADI_EPPI     *pDevice;
    /* register value */
    uint32_t RegValue;
    /* debug build only */
#ifdef ADI_DEBUG
    /* validate device handle */
    if(ValidateEppiHandle(hDevice) != ADI_EPPI_SUCCESS)
        return ADI_EPPI_INVALID_HANDLE;
#endif
pDevice = (ADI_EPPI *) hDevice; //
    /* read register */
    RegValue = pDevice->pRegs->EPPI_CONTROL;
    /* clear field bits from register */
When I run the step of the grey line I get the following message in my console window:
Loading application: "C:\DVT-projecten\projects\NVDI camera\rev06\Blackfin\rev_1_1\D4480_r1_1\Debug\D4480_r1_1.dxe"
Load complete.
A non-recoverable error or exception has occurred.
Description:   A data CPLB miss has occurred without a corresponding CPLB entry.
General Type:  RunTimeError
Specific Type: DCPLBMissWithoutReplacement
  Error PC:      0x11a027b4
With the example FrameCaptureToFile from ADI I get the same errore message:
This is from the function : uint32_t SubmitEmptyVideoFrame(void):
    /* Return code */
    ADI_MT9M114_RESULT eResult;
    /* IF (we've an empty video frame) */
    if (pVideoBufToSubmit->bIsEmpty)
/* IF (Sensor can accept more frame) */
        if (NumBufsInUse <= 1)
With the debugger I just made the step on the grey line. In my console window I get now:
Loading application: "C:\DVT-projecten\projects\NVDI camera\rev06\Blackfin\rev_1_0\FrameCaptureToFile\Debug\FrameCaptureToFile.dxe"
Load complete.
  Error PC:      0x11a05404
Any help is appreciated
