AD9852 Parallel Programming Timing Diagram
Question asked by Cdeprez on Jul 11, 2016
Latest reply on Jul 11, 2016 by mcee
Hi everyone,
I'm working on a new experimental set up and I want to use AD9852 as a precise synthesizer.
I would like to use parallel programming and program my DDS output frequency in single tone mode. I am in trouble understanding the schematics which explained how to do parallel writing and above all the sequence to run to change the value of the different registers.
I have a few question on the timing diagram :
Are the data written on edges of WR signal ( rising, falling or both of them) ?
When the DDS determine in which register it should stores the data ?
I have written a sequence to change the value of 3 registers with Address 0, Address 1 and Address 2. In address 0 I want to store Data 0, store Data 1 in Address 1 and to store Data2 in Address 2
You can find the timing diagram of my programming sequence in the enclosed file
Can you tell me if my sequence/timing diagram will allow me to program the AD9852 or if I need to change it ?
Finally, I don't understand what is the default amplitude level of the DDS after a reset. Is it no output ?
Thank you for your help.
