Reading the ADC on BF506F
Question asked by HeikkiL on Jul 3, 2016
Latest reply on Jul 14, 2016 by HeikkiL
Hi there,
I am prototyping a software-defined radio transceiver using an ADSP-506F_EZKIT and the embedded
ad7266 converter. I am able to read the ADC using the Driver library functions in the following way:
loop
   adi_ad7266_IsBufferAvailable();
   if(available)
      adi_ad7266_GetBuffer();
   Receiver processing using the ADC samples;
   adi_ad7266_SubmitBuffer;
However, this principle is very clumsy for typical multi-rate receiver processing, where the whole processing is not executed at the ADC sample rate, but the processing sampling rate is lowered by decimation. A much better way would be to configure the DMA/SPORT/ACM so that the AD converter runs continuously and the ADC results are red in an interrupt or callback handler writing them into an elastic buffer, e.g. a ring buffer, passing the ADC samples to the actual receiver processing. The following simplified pseudo-code depicts the desired principle:
Callback or interrupt handler executed when new AD conversion results ready
   read the AD conversion;
   store the AD samples into a ring buffer;
Processing loop wherein the actual signal processing takes place:
loop
   if(sufficient number of new samples in the ring buffer)
      Receiver processing using the AD samples;
I have found neither proper Driver library functions nor examples for configuring the mechanisms in the manner above.
I would appreciate much any examples and suggestions.
Kind regards,
Heikki
