8-bit 656 script for ADV7611EB1Z, ADV7611EB2Z, ADV7612EB1Z, ADV7612EB2Z, ADV7619
Question asked by vito on Jul 29, 2011
Latest reply on Jun 6, 2014 by DaveD
Hi
Attached is script for evaluation boards:
EVAL-ADV7611EB1Z,
EVAL-ADV7611EB2Z,
EVAL-ADV7612EB1Z,
EVAL-ADV7612EB2Z
It gets 576i (2x) and outputs as an 656 stream 8-bit to encoder. Encoder outputs it as CVBS.
Same script will work for 480i after changing encoder settings to 480i.
Scripts for 656 8/10/12-bit require not only setting appropriate OP_FORMAT_SEL, but also doubling the clock (In red)
Same applies to ADV7619.
98 FF 80 ; I2C reset
98 F4 80 ; CEC
98 F5 7C ; INFOFRAME
98 F8 4C ; DPLL;
98 F9 64 ; KSV
98 FA 6C ; EDID;
98 FB 68 ; HDMI
98 FD 44 ; CP
98 01 06 ; Prim_Mode =110b HDMI-GR
98 02 F5 ; Auto CSC, YCrCb out, Set op_656 bit
98 03 00 ; 8 bit 656
98 04 00 ; OP CH SEL = 0x0
98 05 2C ; AV Codes On
98 0B 44 ; Power up part
98 0C 42 ; Power up part
98 15 80 ; Disable Tristate of Pins
98 19 C3 ; LLC DLL phase
98 33 40 ; LLC DLL enable
44 BA 01 ; Set HDMI FreeRun
64 40 81 ; Disable HDCP 1.1 features
68 9B 03 ; ADI recommended setting
68 00 08 ; Set HDMI Input Port A (BG_MEAS_PORT_SEL = 001b)
68 02 03 ; Enable Ports A & B in background mode
68 83 FC ; Enable clock terminators for port A & B
68 6F 08 ; ADI recommended setting
68 85 1F ; ADI recommended setting
68 87 70 ; ADI recommended setting
68 8D 04 ; LFG Port A
68 8E 1E ; HFG Port A
68 1A 8A ; unmute audio
68 57 DA ; ADI recommended setting
68 58 01 ; ADI recommended setting
68 75 10 ; DDC drive strength
68 90 04 ; LFG Port B
68 91 1E ; HFG Port B
56 17 02 ; Reset Encoder
56 00 FC ; Power up DACs and PLL
56 01 00 ; SD-SDR only mode
56 02 00 ;
56 80 11 ; PAL mode
56 82 C1 ; SD Pixel data valid
56 88 00 ; 8-BIT INPUT;   Disable SFL
56 8A 08 ; Disable SFL; AVCODES IN
56 8C CB ;   Set Fsc to PAL
56 8D 8A ;
56 8E 09 ;
56 8F 2A ;
vito
