BF536 hangs on reboot after flash operation
Question asked by jon_harris8 on Jun 28, 2016
Latest reply on Aug 3, 2016 by Aaronwu
I have a problem where when I attempt to reboot a BF536, it hangs.  The last thing from the serial port printout is:
Restarting system.ý
(Several different single non-ASCII characters appear at the end of the message.)
This is very intermittent.  The most reliable way I have found to trigger it is with large flash writes just before the reboot.  I am using UBIFS with a fairly slow serial NOR flash.
When it hangs, if I physically short the reset line to ground, it reboots as expected.  The reboot is accomplished with the system reboot command, i.e.
system("reboot");  from C code or 'reboot' from the command line.
The test I've been using is to run 'tar' to extract about 100 uncompressed files from a 5 MB archive, call 'sync', wait a variable amount of time, then 'reboot'.  All this is being done by a shell script.  With little or no pause between sync and reboot, it fails fairly often, maybe 1 out of 10.  With a pause of 60 seconds, failure rates decrease, but still happen.
Any ideas on this one?
