Y and Z axes are disabled (ADXL362)
Question asked by billbucket on Jun 27, 2016
Latest reply on Jun 30, 2016 by billbucket
I'm using a couple of ADXL362 development boards and can't seem to get anything but zeros for the Y and Z axes. The issue is with both the development boards and two replacement ADXL362 I reworked onto one of the boards.
I have tried reading the specific axes directly, burst reading all the axes, burst reading all the registers, saving to the FIFO and reading those values. I have also tried the test mode, the x-axis changes as expected, but again Y and Z are both zero.
In the case of the FIFO read, it appears that the FIFO isn't even storing the Y and Z axes. The samples all have 00 (x-Axis) for their header, unless I include temperature data, then the sample headers alternate between 00 (x-Axis) and 11 (Temp Data). It seems as if the Y and Z axes don't even exist.
I have attached screenshots from my digital logic analyzer. A full register burst read, an MSB axis burst read, a full bit-width axis burst read, and the FIFO read showing only x-axis values.
The EVB devices were marked as:
362X
#252
8303
The replacement ADXL was marked with:
362B
#611
9976
Is this a common failure? Is there some setting I'm missing? To my knowledge, I can't enable or disable the Y and Z axes, correct?
I'm not sure if AD has their distributors burn the ROM to downgrade dies to different part numbers, but it's the only explanation I can think of, since all these parts came from Mouser.
