DCXO temperature compensation
Question asked by emi11 on Jun 21, 2016
Latest reply on Jun 22, 2016 by emi11
OS: Linux
Board: FMCOMMS3
The board is equipped with an 40 MHz DCXO. I calibrated the DCXO with an frequency counter attached to CLK_OUT by adjusting dcxo_tune_coarse & dcxo_tune_fine.
However over time the CLK_OUT changes due to temperature change of the board.
In AD9361 WIKI there is an hint to compensate this behaviour using the on board temperature sensor.
I found that the temperature can be calcuted using XADC device (not sure if this is correct):
(raw-offset)/scale
Example:
root@analog:/sys/bus/iio/devices/iio:device2# cat in_temp0_raw
2669
root@analog:/sys/bus/iio/devices/iio:device2# cat in_temp0_offset
-2219
root@analog:/sys/bus/iio/devices/iio:device2# cat in_temp0_scale
123.040771484
This gives 39.7 C
Is there a formula available for DCXO tuning based board temperature or do I have to measure and build a lookup table by interpolation??
