  AD9361 An error pop up when I compile hdl_2015_r1/library
Question asked by Songbarry on Jun 19, 2016
Latest reply on Jun 29, 2016 by DragosB
Hello:
I use ZC706 and AD-FMCOMMS3-EBZ to do my experiments and verify some communication chain. Because I get the board for few days, I wish to consult you on a few questions if it is convinent for you. Thank you in advance.
1
I am compiling hdl_2015_r1/library in vivdo2014.4 and follow the instruction
https://wiki.analog.com/resources/fpga/docs/hdl#building_hdl
but when I type command “cd” and “source ./ XXXX”, but an error pop up like this “error, this library requires vivado2014.4 when executing “adi_ip_create axi_ad9361” ”., and the attachment is the picture. I am very confused with this, because I am using vivado2014.4. Please help me, thank you
2
if I want to run the example in the code no-OS-master\ad9361\sw, which may generate an sin with 1MHz I need how to config in the file config.h? If I config like this, can everything is ok?
//#define CONSOLE_COMMANDS
#define XILINX_PLATFORM
//#define ALTERA_PLATFORM
//#define FMCOMMS5
//#define PICOZED_SDR
//#define PICOZED_SDR_CMOS
#define CAPTURE_SCRIPT
//#define AXI_ADC_NOT_PRESENT
If this configuration is right, how can I get the output data, I can see somebody mention that a csv file may generate, but how? If I run this code, a csv file could be generated by this code?
My question may be very simple, but I have been confused for sometime, I will really be very grateful to you if you can help me
