FMCDAQ2 : issues at DAC ouput
Question asked by amai on Jun 15, 2016
Latest reply on Jun 22, 2016 by larsc
I'm using the AD-FMCDAQ2-EBZ with the KC705 board.
1/ I wrote a sequence with scilab that I send to the DAC with the IIO Oscilloscope(with the buffer), this sequence looks like this:
But when I measure the DAC output at the oscilloscope, here is what I see:
An exponential component can clearly be dinstinguished where I should get the DC levels. Moreover, higher the voltage level is, the more the exponential is pronounced. Do you know where does it come from? What would i have to do to get my initial sequence at the dac output?
2/ I'd like not to use the IIO oscilloscope to transmit the sequences to the DAC because with this method i always have to load a different text file and for a real-time application, this is not appropriated. Is there a way to do it from the microblaze with the SDK software?
Thanks in advance,
Alexandre
