Using adi_osal.h to develop OS project
Question asked by 4tunato on Jun 6, 2016
Latest reply on Jun 17, 2016 by Kader.M
for my new project i want to start developing using adi_osal.h
and for now link to VDK while in second time migrate to other RTOS
probably ucOS.
Actually i found few help on your documentation.
I have understood that in main i have as usual call
adi_ssl_Init();
After that fill the structure ADI_OSAL_CONFIG *pConfig and call
adi_osal_Init(pConfig);
In particular can you explain me the meaning of each fields and typicals
value i.e.
typedef struct __AdiOsalConfig
    ADI_OSAL_PRIO_INHERIT_OPTION    eEnablePrioInherit;             /* set priority inheritance initialization option */
    uint32_t                        nNumTLSSlots;                   /* number of TLS allocated (for each thread) */
    uint32_t                        nSysTimerPeriodInUsec;          /* indicate the system tick period in microseconds */
    void                            *pHeap;                         /* pointer to a memory location to use as a heap (4-bytes aligned) */
    uint32_t                        nHeapSizeBytes;                 /* size of the Heap in bytes */
} ADI_OSAL_CONFIG, *ADI_OSAL_CONFIG_PTR;
What is the priority inheritance?
what is TLS and what is its value
Where do i find pHeap? in linker file?
Then i understood i have to create at least the starting thread as the last function
to call adi_osal_OSStart needs the starting thread. is it correct?
Do i miss any step?
Can you give me a link or sample project to find information?
Regards.
