Booting Linux failed with a new 1.0 silicon version ezkit
Question asked by whuanghq on Jun 1, 2016
Latest reply on Jun 5, 2016 by Aaronwu
I just got a new 1.0 silicon version sc589 ezkit, uboot was fine, but booting linux failed, below was the steps i followed the ezkit quick starter guide
1) Booting Linux Standalone From Non-Volatile Storage
U-Boot 2015.01 ADI-1.0.1 (May 04 2016 - 20:33:27), Build: jenkins-label=make_deb_package-228
CPU:   ADSP ADSP-SC589-0.0 (Detected Rev: 1.1) (spi flash boot)
VCO: 450 MHz, Cclk0: 450 MHz, Sclk0: 112.500 MHz, Sclk1: 112.500 MHz, DCLK: 225 MHz
OCLK: 150 MHz
I2C:   ready
DRAM:  224 MiB
MMC:   GRIFFIN SDH: 0
SF: Detected W25Q128BV with page size 256 Bytes, erase size 4 KiB, total 16 MiB
In:    serial
Out:   serial
Err:   serial
other init
Net:   dwmac.3100c000
Hit any key to stop autoboot:  5     4     0
sc # tftp 0xc2000000 vmImage-sc58x-ezkit-hpc
Speed: 1000, full duplex
Using dwmac.3100c000 device
TFTP from server 192.168.3.7; our IP address is 192.168.3.33
Filename 'vmImage-sc58x-ezkit-hpc'.
Load address: 0xc2000000
Loading: * #################################################################
  2.2 MiB/s
done
Bytes transferred = 5605856 (5589e0 hex)
sc # sf probe 2:1
sc # sf erase 0xa00000 0x600000
SF: 6291456 bytes @ 0xa00000 Erased: OK
sc # sf write 0xc2000000 0xa00000 ${filesize}
SF: 5605856 bytes @ 0xa00000 Written: OK
Load and Flash the DTB File
sc # tftp 0xc2000000 sc58x-ezkit-hpc.dtb
Filename 'sc58x-ezkit-hpc.dtb'.
Loading: * ##
  1.7 MiB/s
done
Bytes transferred = 18018 (4662 hex)
sc # sf probe 2:1
sc #  sf erase 0x900000 0x40000
SF: 262144 bytes @ 0x900000 Erased: OK
sc # sf write 0xc2000000 0x900000 ${filesize}
SF: 18018 bytes @ 0x900000 Written: OK
Customize the u-boot environment
sc # set bootargs root=/dev/mmcblk0p1 rw rootwait rootfstype=ext3  clkin_hz=(25000000) earlyprintk console=ttySC0,57600
sc # sf probe 2:1
sc #     sf read 0xc4000000 0x900000 0x5000
SF: 20480 bytes @ 0x900000 Read: OK
sc # sf read 0xc2000000 0xa00000 0x600000
SF: 6291456 bytes @ 0xa00000 Read: OK
sc # bootm ${loadaddr} - ${dtbaddr}
Wrong Image Format for bootm command
ERROR: can't get kernel image!
2)Quicker Boot From Non-Volatile Storage
sc # set sdargs set bootargs root=/dev/mmcblk0p1 rw rootwait rootfstype=ext3 clkin_hz=(25000000) earlyprintk console=ttySC0,57600
sc # set sdboot 'run sdargs; sf probe 2:1;sf read 0xc4000000 0x900000 0x5000;ext2load mmc 0:1 0xc2000000 vmImage-sc58x-ezkit-hpc;bootm ${loadaddr} - ${dtbaddr}'
sc # set bootcmd run sdboot
sc # run sdboot
5605856 bytes read in 417 ms (12.8 MiB/s)
## Booting kernel from Legacy Image at c2000000 ...
   Image Name:   Linux-4.0.0-ADI-1.0.1
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    5605792 Bytes = 5.3 MiB
   Load Address: c2008000
   Entry Point:  c2008000
   Verifying Checksum ... OK
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
