AD9361 SPECTRUM problem
Question asked by analotus on May 29, 2016
Latest reply on Jun 2, 2016 by mhennerich
I use AD9361 designs these days, but I meet some problem.
I made the below frequency assignments in my system:
uint32_t Rx_clkfreq[6]={1280 000000, 80 000000, 80 000000, 80 000000, 40 000000, 40 000000};
uint32_t Tx_clkfreq[6]={1280 000000, 80 000000, 80 000000, 80 000000, 40 000000, 10 000000};
Accroding to the reference design in NO OS main.c:
uint32_t Rx_clkfreq[6]={786432000, 24576000, 12288000, 6144000, 3072000, 3072000};
uint32_t Tx_clkfreq[6]={786432000, 12288000, 12288000, 6144000, 3072000, 3072000};
There's some problems,
1)
Is it correct to use two differenct sample frequencies,  40M and 10M as above,  for receving and transmitting at the same time?
2)
For the  transmitting link,
I use a raised cosine FIR filter with fs=40 000000,  -3dB frequnce point  5Mhz.
I send 10Mhz  psedorandom  +/- 512 series  to stimulate the transmitt FIR input port.
Configurations:
1R1T FDD,
LVDS mode,
FPGA lvds port:
fb_clk: frequency  20Mhz
tx_frame: frequency  10Mhz
txd:   40Msps,  ddr data flow with muxed Imsb,Qmsb, Ilsb, Qlsb
tx_lo_freq to 140Mhz,
And I wish I will get a  raised cosine spetrum with 3dB-bandwith around 140Mhz.
The effect I  need is:between each two 10Msps baseband +/-512 data point will be 3 inserted zeros, then  the 4x interpolted 40MHZ data  flow go into  the 40Mhz-sample- rate rasied cosine FIR.
But I failed,  the spectrum's outline is defined the by the raised cosine spetrum with 3dB-bandwith.
But the inner part is 2*5Mhz main sinc spectrum.
The effect seemed  equals the 10Msps baseband +/-512 data flow has been decimated to 5Msps, and between each two none zero point, insert 7 zeros,  then passed the 40Mhz sample rate rasied cosine FIR.
What's wrong?
Will you please give some advice?
Thanks in advance for your kindly help.
Micah
