AD5933 Measurement (Status Reg)
Question asked by Maemo on May 26, 2016
Latest reply on Jul 1, 2016 by Maemo
im pretty new in programming IC's so please excuse my mistakes if they are dumb. So i use a Raspberry Pi for the communication and my code is in Python. My problem is i always keep getting 0x60, 0x66 in the Status Register which makes no sense. Just sometimes i get 0x62 which should indicate valid real/img data. As a result my measurements are wrong. I can show you my code maybe there are some mistakes
import smbus
import math
bus = smbus.SMBus(1)
ADRESSE = 0x0D
j=0
x=0
#Startfrequency
bus.write_byte_data(ADRESSE, 0x82, 0x07)          #051EB8 @10khz #028F5C @5khz
bus.write_byte_data(ADRESSE, 0x83, 0xAE)         #0F5C28 @30khz #07AE14 @15 khZ
bus.write_byte_data(ADRESSE, 0x84, 0x14)          #199999 @50khz #0CCCCC @25khz
#Frequency increment
bus.write_byte_data(ADRESSE, 0x85, 0x00)          #00014F @10hz
bus.write_byte_data(ADRESSE, 0x86, 0x41)          #004189 @500hz
bus.write_byte_data(ADRESSE, 0x87, 0x89)
#Number of increments
bus.write_byte_data(ADRESSE, 0x88, 0x00)
bus.write_byte_data(ADRESSE, 0x89, 0x96)
#Control Register Settling Time Cycles
bus.write_byte_data(ADRESSE, 0x8A, 0x00)
bus.write_byte_data(ADRESSE, 0x8B, 0x32)
#Control Register Standby Mode
bus.write_byte_data(ADRESSE, 0x80,bus.read_byte_data(ADRESSE,0x80)&0x07 |0xB0)
#Control Register Initialiaze with start frequency
bus.write_byte_data(ADRESSE, 0x80, bus.read_byte_data(ADRESSE,0x80)&0x07 |0x10)
  #Control Register Start Frequency Sweep
bus.write_byte_data(ADRESSE, 0x80, bus.read_byte_data(ADRESSE,0x80)&0x07 |0x20)
  #Control Register Increment Frequency
bus.write_byte_data(ADRESSE, 0x80, bus.read_byte_data(ADRESSE,0x80)&0x07 |0x31)
bus.write_byte_data(ADRESSE, 0x81, bus.read_byte_data(ADRESSE,0x80)&0x07 |0x00)
while x<8000:
  status = bus.read_byte_data(ADRESSE,0x8F)
  if status==0x62:
  real1= bus.read_byte_data(ADRESSE, 0x94)
  real2= bus.read_byte_data(ADRESSE, 0x95)
  imag1= bus.read_byte_data(ADRESSE, 0x96)
  imag2= bus.read_byte_data(ADRESSE, 0x97)
  r= (real1*256)+real2
  i= (imag1*256)+imag2
  #Magnitude Calculation
b=math.sqrt((r**2)+(i**2))
  #Gain Factior
  c=4.62e-11                #515.819e-12 #5.39e-11#6.93e-11
  #Impedance Calculation
  z=1/(b*c)
  print (z)
  print (r)
  print ( i)
  print (status)
  break
  if status!=0x62:
bus.write_byte_data(ADRESSE, 0x80,bus.read_byte_data(ADRESSE,0x80)&0x07 | 0x30)
print(status)
  x=x+1
