Issues with AD7705 not sending data
Question asked by hanut123 on May 25, 2016
Latest reply on May 26, 2016 by hanut123
I wanted to use the AD7705 with some load cells and was trying to set it up with a POT first.
My connection is with an arduino UNO with connection diagram attached.
Now, when working with it, i have analyzed the main signals on a DSO and have a Serial clock, Master clock (2Mhz), the /dataready pin goes every once in a while. But, i am unable to get any output from the SPI command (what i feel).
I am attaching the code for reference.
Arduino Code:
#include <SPI.h>
const int drdy = 6;
const int cs = 10;
const int freqOutputPin = 3;
const int ocr2aval  = 3;
const int prescale  = 1;
const float period    = 2.0 * prescale * (ocr2aval+1) / (F_CPU/1.0e6);
const float freq      = 1.0e6 / period;
void setup()
  pinMode(freqOutputPin, OUTPUT);
  Serial.begin(9600);
  SPI.begin();
  //SPI.beginTransaction(SPISettings(200,MSBFIRST,SPI_MODE0));
  pinMode(drdy,INPUT);
  pinMode(cs,OUTPUT);
  digitalWrite(cs,LOW);
  TCCR2A = ((1 << WGM21) | (1 << COM2B0));
  TCCR2B = (1 << CS20);
  TIMSK2 = 0;
  OCR2A = ocr2aval;
  Serial.print("Period    = ");
  Serial.print(period);
  Serial.println(" microseconds");
  Serial.print("Frequency = ");
  Serial.print(freq);
  Serial.println(" Hz");
  writetoadc(0x20);
  delay(100);
  writetoadc(0x03);
  delay(100);
  writetoadc(0x10);
  delay(100);
  writetoadc(0x40);
  delay(100);
void loop()
  while(digitalRead(drdy)==1);
  writetoadc(0x38);
  int value = getadcdata();
  Serial.print("Value:");
  Serial.println(value);
void writetoadc(byte command)
  SPI.transfer(command);
  //SPI.endTransaction();
  digitalWrite(MOSI,HIGH);
  return;
int getadcdata()
  unsigned int result = 0;
  byte input = 0;
  result = SPI.transfer(0x00);
  result = result << 8;
  input = SPI.transfer(0x00);
  result = result | input;
  //digitalWrite(MOSI,HIGH);
  return (result);
Thanks! Cheers!
P.S. the resistances are 2K4 each.
