Changing AD9361 RX hardware gain
Question asked by amy_s on May 23, 2016
Latest reply on Jan 23, 2018 by mhennerich
I'm using a zedboard and AD-FMCOMMS2-EBZ and trying to change the gain on the receive channels.
I have tried calling code which results in
long long hwgain = <new gain setting>
iio_channel_attr_write_longlong(channel, "hardwaregain", hwgain)
but there this doesn't seem to change the gain, and doesn't seem to result in an error return code, either.
I'm also not able to change the gain through the shell:
root@analog:/sys/bus/iio/devices/iio:device1# echo "61.000000" > in_voltage0_hardwaregain
root@analog:/sys/bus/iio/devices/iio:device1# cat in_voltage0_hardwaregain
71.000000 dB
root@analog:/sys/bus/iio/devices/iio:device1# echo 62 > in_voltage0_hardwaregain
71.000000 dB
I'm able to change other attributes, such as :
root@analog:/sys/bus/iio/devices/iio:device1# cat in_voltage_rf_bandwidth
18000000
root@analog:/sys/bus/iio/devices/iio:device1# echo 17000000 > in_voltage_rf_bandwidth
17000000
However, if I change the gain through the Matlab IIO System Object, from then onwards, I can change the gain from the shell:
61.000000 dB
62.000000 dB
I'd like to know how I can do this from C program using libiio, but I'm not sure if being able to change it from the shell is related.
Amy
