AD9675 programming and JESD204B lane rate
Question asked by tonyle on May 23, 2016
Latest reply on Mar 12, 2018 by zimou13
I'm trying to debug the JESD204B link between two AD9675's and our FPGA receiver (Xilinx 7 series). We are not achieving sync between the devices (as indicated by the FPGA holding SYNCINB low). I'd like to make sure I've calculated the ADC lane rate correctly and that the programming sequence is correct.
The FPGA core is configured to receive data at 2.0 Gbps on each lane, and I've configured the ADCs in such a way that I believe the lane rate should be 2.0 Gbps. As far as I can tell, the data sheet (Rev. A) doesn't specifically give a formula for thisr; rather, the specification for IDRVDD on page 6 implies that the data rate in a four-lane configuration is 20 times the CLK speed for Modes III and IV (assuming the RF decimator is turned on). We are using a 100 MHz clock which is how I inferred 2.0 Gbps. Am I correct?
Here also is the ADC programming sequence. I'm especially curious about 0x181, the PLL N-divider setting. There isn't any information about this setting beyond the short entry in the register table.
Thanks for your help!
Address
Data
Operation
0x142
0x01
Power down JESD204B link
0x000
0x3C
Initiate SPI reset
0x002
0x30
Set speed mode to 125 MSPS
0x0FF
0x01
Enable speed mode change
0x004
0x0F
Set local registers to all channels
0x005
0x3F
0x113
0x04
Enable RF decimator and low-bandwidth filter, enable high-pass filter
0x011
0x06
Set LNA gain = 21.6 dB, GAIN± pins enabled, and PGA gain = 24 dB
0xF00
0xFF
Continuous run mode enable; do not power down channels (POWER_STOP LSB)
0xF01
0x7F
Continuous run mode enable; do not power down channels (POWER_STOP MSB)
0xF02
0x00
Power up all channels 0 clock cycles after TX_TRIG± signal assertion (POWER_START LSB)
0xF03
0x80
Digital high-pass bypassed (POWER_START MSB)
0x10C
0x00
Set index profile (required after profile memory writes)
0x014
0x01
Set output data format
0x008
0x00
Chip run (TGC mode)
0x021
0x12
16-bit, four-lane mode
0x199
0x80
Enables automatic serializer/deserializer (SERDES) sample clock counter
0x188
0x01
Enable start code identifier
0x18B
0x27
Set start code MSB
0x18C
0x72
Set start code LSB
0x150
0x83
JESD204B scrambler enabled and four-lane configuration (L = 4)
0x182
0x82
Automatically configures PLL
0x181
0x01
PLL N-divider = ÷10
0x10C
0x20
Set SPI TX_TRIG and index profile
0x00F
0xB0
Set antialiasing LPF cutoff frequency to 6.25 MHz (0.75/6 × 50 MHz), low bandwidth mode
0x02B
0x43
Set analog HPF cutoff frequency to 2.083 MHz (LPF cutoff/3.0), tune filters
0x186
0xAA
Disable continuous data resync (continuous data resync is not recommended during real-time scanning; one time data resync is sufficient)
0x142
0x14
Power up JESD204B link, ILAS enabled, lane sync enabled
