ADV7611 multiburst test issue
Question asked by robin.hu Employee on May 20, 2016
Latest reply on May 20, 2016 by mattp
1.System:
Setop Box HDMI(YCbCr444 or RGB, ASIC is HISI3716)-->ADV7611(16bit SDR YPbPr4:2:2)-->GS2972(serializer)-->SDI-->WFM700
2.Issue:
1) HDMI source-->BlackMatic converter-->SDI-->WFM700, to verify that multiburst test passed for both HD&SD.
2) With ADV7611, SD test ok
3) With ADV7611, HD test(1080i@50Hz) failed, Pr peak to peak amplitude is not flat, see attached result.
3. Configuration(reference from ADI):
// Assign Part Address
      I2C_RegWrite( ADDR_IO, 0xF4, ADDR_CEC  );    // CEC
      I2C_RegWrite( ADDR_IO, 0xF5, ADDR_INFO );    // INFOFRAME
      I2C_RegWrite( ADDR_IO, 0xF8, ADDR_DPLL );    // DPLL
      I2C_RegWrite( ADDR_IO, 0xF9, ADDR_KSV  );    // KSV
      I2C_RegWrite( ADDR_IO, 0xFA, ADDR_EDID );    // EDID
      I2C_RegWrite( ADDR_IO, 0xFB, ADDR_HDMI );    // HDMI
      I2C_RegWrite( ADDR_IO, 0xFD, ADDR_CP );        // CP
// General config
      I2C_RegWrite( ADDR_IO, 0x00, 0x14); // HD 1x1,1920x1080
      I2C_RegWrite( ADDR_IO, 0x01, 0x15 ); // 50Hz,HDMI_COMP
      I2C_RegWrite( ADDR_IO, 0x02, 0xF4 ); //Input color space depends on color space
reported by HDMI block.,Enables limited output range (16 to 235), Auto CSC,YCrCb out, Set op_656 bit
      I2C_RegWrite( ADDR_IO, 0x03, 0x80); //0x80=16-bit ITU-656 SDR mode,0x90=16-bit SDR 4:2:2 Mode 4
//      I2C_RegWrite( ADDR_IO, 0x05, 0x2C);    //AV Codes Insert
      I2C_RegWrite( ADDR_IO, 0x06, 0xA6 );    //Invert VS,HS pins
      I2C_RegWrite( ADDR_IO, 0x0B, 0x44 );    //Power up part
      I2C_RegWrite( ADDR_IO, 0x0C, 0x42 );//Power up part
      I2C_RegWrite( ADDR_IO, 0x14, 0x7F);    //Max Drive Strength
      I2C_RegWrite( ADDR_IO, 0x15, 0x80 );    // Disable Tristate of Pins
      I2C_RegWrite( ADDR_IO, 0x19, 0x8F);    //Enables LLC DLL,LLC DLL phase
      I2C_RegWrite( ADDR_IO, 0x33, 0x40 );    //Muxes the DLL output on LLC output
      I2C_RegWrite( ADDR_CP, 0xBA, 0x01 );    //Set HDMI FreeRun
      I2C_RegWrite( ADDR_KSV, 0x40, 0x81 );    //Disable HDCP 1.1 features
      I2C_RegWrite( ADDR_HDMI, 0x9B, 0x03 );    //ADI recommended setting
      I2C_RegWrite( ADDR_HDMI, 0x00, 0x08 );    // Set HDMI Input Port A (BG_MEAS_PORT_SEL =
001b)
      I2C_RegWrite( ADDR_HDMI, 0x02, 0x03 );    // Enable Ports A & B in background mode
      I2C_RegWrite( ADDR_HDMI, 0x83, 0xFC );    //Enable clock terminators for port A & B
      I2C_RegWrite( ADDR_HDMI, 0x6F, 0x0C );    //ADI recommended setting
      I2C_RegWrite( ADDR_HDMI, 0x85, 0x1F );    // ADI recommended setting
      I2C_RegWrite( ADDR_HDMI, 0x87, 0x70 );    // ADI recommended setting
      I2C_RegWrite( ADDR_HDMI, 0x8D, 0x04 );    //LFG Port A
      I2C_RegWrite( ADDR_HDMI, 0x8E, 0x1E );    //HFG Port A
      I2C_RegWrite( ADDR_HDMI, 0x1A, 0x80 );    //unmute audio,8A?
//      I2C_RegWrite( ADDR_HDMI, 0x39, 0x02 );    //48K sample
      I2C_RegWrite( ADDR_HDMI, 0x57, 0xDA );    // ADI recommended setting
      I2C_RegWrite( ADDR_HDMI, 0x58, 0x01 );    // ADI recommended setting
      I2C_RegWrite( ADDR_HDMI, 0x75, 0x10 );    // DDC drive strength
      I2C_RegWrite( ADDR_HDMI, 0x90, 0x04 );    // LFG Port B
      I2C_RegWrite( ADDR_HDMI, 0x91, 0x1E );    // HFG Port B
      I2C_RegWrite( ADDR_CP, 0xBD, 0x10); //Set DPP_BYPASS_EN to 1 to use the CP CSC,Address 0xBD[4]
      I2C_RegWrite( ADDR_HDMI, 0x1D, 0x00); //SettingSet UP_CONVERSION_MODE to 0,Address 0x1D[5]
      I2C_RegWrite( ADDR_IO, 0xE0, 0x80); //DS_WITHOUT_FILTER,Address 0xE0[7]: 1=downstreeam and
no-filter,0=downstreeam and filter
      I2C_RegWrite( ADDR_CP, 0xC9, 0x2D); //Set DIS_AUTO_PARAM_BUFF (CP Map, 0xC9[0]) slave free-run
parameters from PRIM_MODE and VID_STD
//      I2C_RegWrite( ADDR_IO, 0xBF, 0x01); // 1= HDMI data directly fed to output bypassing CP completely
      I2C_RegWrite( ADDR_CP, 0x3E, 0x80); //VID_ADJ_EN, Addr 44 (CP), Address 0x3E[7],1=Enable color
controls
      I2C_RegWrite( ADDR_CP, 0x3A, 0x80); //CP_CONTRAST[7:0]
      I2C_RegWrite( ADDR_CP, 0x3B, 0x80); //CP_SATURATION[7:0]
      I2C_RegWrite( ADDR_CP, 0x3C, 0x00); //CP_BRIGHTNESS[7:0]
      I2C_RegWrite( ADDR_CP, 0x3D, 0x00); //CP_HUE[7:0]
