ADSPBF-706, SEC, Interrupt priorities
Question asked by Dimitry. on May 17, 2016
Latest reply on Jun 17, 2016 by Dimitry.
I have a question about SEC in ADSPBF-706. The same question was asked here: https://ez.analog.com/message/150911#comment-150911 and I made the next conclusion:
For example, I activate two interrupts TMR1 (SID = 12) and PINT0 (SID = 20). When the TMR1 interrupt is asserted , while running the PINT0 ISR, immediately PC calls the TMR1 ISR, even the PINT0 ISR is not completed.
But in the practice I got this result: Controller executes PINT0 ISR, finished it and only after this goes to the high priority interrupt TMR1 (with more higher ID in  ADSP-BF70x Interrupt List). In the Source Control Register all priority levels are set by default = 0.
     Started PINT0 ISR –> Asserted TMR1 ISR –> Finished PINT0 ISR –> Started TMR1 ISR
After priorities are set manually, SEC became to work correctly:
     Started PINT0 ISR –> Asserted TMR1 ISR –> Finished TMR1 ISR –> Continued PINT0 ISR
Could you tell me please it’s necessary to set up manually all interrupt priorities with the Source Control Registers, even if in Hardware Manual is written:
“… if SID 0, SID 1, and SID 2 are all pending and have the same priority setting, the SCI chooses SID 0 as the highest priority pending system interrupt source”
Thank you,
Dmitry
