version of python
Question asked by michaelbrianbentley on May 17, 2016
Latest reply on May 19, 2016 by michaelbrianbentley
I have installed the most recent version of uClinux for blackfin and the gnu toolchain for blackfin, both vintage 2014.
blackfin-toolchain-2014R1_45-RC2.x86_64.tar.bz2
There are two other compressed archives that I'm not using, one for elf and one for linux-uclibc, but I have them. These other two archives appear to be of the same vintage (2014R1_45-RC2).
I have set this up in /opt/uClinux of a vintage 2014 ubuntu partition on an intel machine, and did a hello world test build that worked on the target blackfin system.
Now I'm trying to build python for running on the blackfin device. I'm building python 2.7.11 using:
CONFIG_SITE=config.site ./configure --host=blackfin-uclinux --build=i686-linux --exec-prefix=/opt/uClinux/bfin-uclinux/bfin-uclinux/runtime/usr --prefix=/opt/python --disable-ipv6
Upon running make clean ; make I see build errors. See below.
Would you recommend attempting to build an earlier version of python? Or do you see something obviously w0rng?
myacct:/opt/Python-2.7.11$ make
blackfin-uclinux-gcc -c -fno-strict-aliasing -g -O2 -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes  -I. -IInclude -I./Include   -DPy_BUILD_CORE -o Modules/python.o ./Modules/python.c
In file included from Include/Python.h:85:0,
from ./Modules/python.c:3:
Include/unicodeobject.h:575:20: warning: type defaults to ‘int’ in declaration of ‘wchar_t’
Include/unicodeobject.h:575:28: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token
Include/unicodeobject.h:593:14: warning: type defaults to ‘int’ in declaration of ‘wchar_t’
Include/unicodeobject.h:593:22: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token
make: *** [Modules/python.o] Error 1
It is complaining about missing syntax before the *w in:
PyAPI_FUNC(Py_ssize_t) PyUnicode_AsWideChar(
     PyUnicodeObject *unicode,      /* Unicode object */
     register const wchar_t *w,         /* wchar_t buffer */
     Py_ssize_t size                          /* size of buffer */
The code above should not be a problem.
-Mike
