Is the latest libiio broken intentionally?
Question asked by EdwardK on May 5, 2016
Latest reply on May 25, 2016 by larsc
I am running Gentoo Linux OS and having issues with libiio.
To remove my OS from the equation, I am running ADI's latest image: 2015_R2-2016_04_01.img
1) Obtain sources.
git clone https://github.com/analogdevicesinc/libiio.git
2) Build libiio and iiod.
mkdir -p libiio/build
cd libiio/build
cmake .. -DBUILD_SHARED_LIBS:BOOL=OFF -DWITH_TESTS:BOOL=ON -DWITH_DOC:BOOL=OFF -DENABLE_IPV6:BOOL=OFF -DWITH_IIOD:BOOL=ON -DWITH_NETWORK_BACKEND:BOOL=ON -DWITH_LOCAL_BACKEND:BOOL=ON -DWITH_USB_BACKEND:BOOL=OFF
make
cd iiod/ && ./iiod
3) Use osc to perform test.
TX Chain:
RF BW: 18 GHz
Sampling rate: 30.72 MHz
TX1 attenuation: 0: TX2 attentuation 89
FPGA settings:
TX1: DAC Buffer Output
File Selection: LTE10.mat <- From iio_scope example waveforms.
DAC Channels: Voltage 0 and Voltage1
AD9361 Global Settings:
ENSM Mode fdd
4) Expect to see waveform on output.
Instead osc reports an error on attempt to load file.
5) git checkout 18563161daa5d61c9e404be26e714dbaf0f344f2
Repeat steps 1 thru 4 above and it works.
6) I modified the iiostream example to write the using code from osc to read in the file, and I get errno 110 TIMEOUT when using ADI HDL 2015_r2: 18563161daa5d61c9e404be26e714dbaf0f344f2 & kernel xcomm_zynq: 18563161daa5d61c9e404be26e714dbaf0f344f2
7) Note that the timeout is only if I create a cyclic buffer.
8) To compile the attached code:
gcc -o test ad9361-iiostream.c -L /usr/lib/ -liio -lm -lmatio
larsc @Paul Cercueil
