ADV7341 EVB - SMPTE274M 1080I@50Hz Configuration
Question asked by Amit-L. on May 4, 2016
Latest reply on Jul 13, 2016 by PaulS
Hi
I'm trying to configure the 7431EVB (EVAL-ADV734XEBZ) to work with SMPTE274M 1080I@50Hz.
In the ADV Register Control 6.04 i run the script ADV7403- HD only with SDR EAV/SAV 1080I60 YPbPr In, 20bit 422out. After running this script i can see 1080I60 in the output monitor as expected.
After that i manually chnage the following registers in order to change to 50Hz according to AD application note for AD7403 (Component Processor nonstandard video foramts):
Under 7403:
1.   0x87   PLL_DIV_MAN_EN  = '1'
2.   0x87,0x88   PLL_DIV_RATIO[11:0] = A50  (hex)
3.   0x8A   VCO_RANGE_MAN  = '1'
4,   0x8A   VCO_RANGE[1:0] = "10"
5.   0x8F, 0x90   FR_LL[11:0] = 3C0   9hex)
Under 7341:
1.   0x30    ED/HD INPUT MODE   = 74  (hex)
i connect the SMPTE274M 1080I@50Hz video from a standard bar genrator to the EVB and i don't see any video in the monitor. If i bypass the EVB and connect the bar genrator dirctly to the monitor i see the correct picture so the bar genrator and monitor both support this format.
Thanks
Amit
