What is the fastest way to test a bit?
Question asked by dww on Jul 15, 2011
Latest reply on Jul 25, 2011 by gpan
I often test bits in C using something like:
int result, value, bit;
result = value & (1 << bit);
Since I've been looking at the assembly this code generates I've seen the manual refer to a 'bit tst' instruction.  I'm less good with the assmbler but my guess is that the hardware can test a bit with one instruction.
The above code generates this:
r2=m6;
r2=lshift r2 by r2, r0=m5;
r2=r2 and r2, i12=dm(m7,i6);
I've then seen this in the manual, which (not recommended) tests bit in system registers:
asm("R0 = 0; bit tst MODE1 IRPTEN; if TF r0 = r0 + 1; %0 = r0;"
: "=d"(test) : : "r0");
However, once I try this on my own values it refuses to compile.
I've got as far as changing it to:
int value, bit, result;
asm("r0 = 0; bit tst %1 %2; %0 = r0;" : "=d"(result) : "u"(value), "u"(bit));
but the assember fails to accept the %2 argument, although it does pass if I make a fixed number.  The error is
[Error ea1007] ".\Release\IgnoreChamber.s":26 [column 31] Syntax Error at ";".
with the code it generates
r0 = 0; bit tst ustat1 ustat1; r2 = r0;
Unfortunately I don't understand this enough to fix it.  Can user bits be tested with one instruction or am I waisting my time?  I'll happliy accept any tips on making testing a bit a little faster as I use this technique quite often.
David.
