Differential input voltage of opamp ±0.8 V
Question asked by selvakumar.sonai on Apr 28, 2016
Latest reply on Apr 28, 2016 by Emman.A
Hi
In AD8022 datasheet has Differential Input Voltage  ±0.8 V at absolute maximum rating.
In design i provided the supply voltage as  +/-12V.
i used the amplifier as Voltage follower,inverting amplifier and active filter.
Inverting Amplifier and Filters are unity configuration mode only.
My single ended input signal of opamp is +4Vpeak to -4Vpeak with respect to ground.
Is the signal to be clamped by the internal diodes ?
Similarly i use the opamp of AD8032, ADA4898 .
It also have the differential voltage as +/-3.4V (AD8032) and +/-1.5V(ADA4898).
With regards,
selva
