ADF4351: phase noise and RF N divider values
Question asked by luca.banchi on Apr 27, 2016
Latest reply on Apr 28, 2016 by rbrennan
Dear support,
I adopt the ADF4351 in my design as local oscillator (LO), in particular the LO operates in 4212.5MHz to 4312.5MHz bandwidth with 33 equally spaced channels with 3.125MHz fixed separation. The input reference is a 100MHz signal.
In this configuration, the ADF4351 works as Integer-N PLL and I adopt the following values for the RF dividers:
R = 32 (fixed), or 16 (fixed) enabling ÷2 divider;
D = 0;
T = 0;
FRAC = 0;
MOD = 2;
DIV = 1;
INT spans between 1348 to 1380;
My concerning is about the ADF4351 output phase noise in this configuration where the INT values has a quite high absolute value and it spans over a wide range of values.
Does the value of INT and R divider could influence the phase noise performance in any way?
Simulating with ADIsimPLL the ADF4351 output it seams no degradation in the SSB spectrum for every value of INT, is it correct?
Thank you for your reply
