Arduino Uno with AD9958
Question asked by Care07 on Apr 26, 2016
Latest reply on Jul 5, 2017 by vandenplas
I am having difficulty getting an output using the Arduino Uno to control the AD9958. The Eval board is in Manual Mode. I've attached SCLK on U2 to Pin 13 on the Arudino,  SDIO_0 on U13 to Pin 11 on the Arduino, IO_UPDATE on U2 to a digital output pin on the Arduino, RESET on U2 to a digital output pin on the Arduino, and CSB on U2 to Pin 10 on the Arduino.
I have analyzed my output using an oscilloscope and I am sending the correct bytes to the board. The board just doesn't seem to respond?
I could really really really use some help!
Here is my code:
#include <SPI.h>
const int CSPin =10;
const int IOUpdatePin = 7; //The pin used to trigger IO UPdate events.
const int ResetPin = 4; //The pin used to send reset commands.
void setup (void)
  pinMode (IOUpdatePin, OUTPUT); //Set the IO Update Pin to Output.
  pinMode (ResetPin, OUTPUT);//Set the Reset Pin to Output.
  pinMode (CSPin, OUTPUT); //Set the chip select pin to Output.
  digitalWrite(CSPin, HIGH);  // ensure SS stays high
  SPI.begin ();
SPI.setClockDivider(SPI_CLOCK_DIV2);
  SPI.setBitOrder (MSBFIRST);
  SPI.setDataMode (SPI_MODE0);
  digitalWrite (ResetPin, HIGH); //The reset is active on logic high, so we set the pin to high for an update.
  digitalWrite (ResetPin, LOW); //Then setting it to low ends it. The delay between rise and fall is many clock cycles (of the DDS),
  digitalWrite(CSPin, LOW);// ensure SS is low.
  SPI.transfer (0x00);//write to CSR (Channel Select Register)
  SPI.transfer (0x80);
  digitalWrite (IOUpdatePin, HIGH); //The IO Update is active on logic high, so we set the pin to high for an update.
  digitalWrite (IOUpdatePin, LOW); //Then setting it to low ends it. The delay between rise and fall is many clock cycles (of the DDS),
  //so no delay between the high and low commands is needed.
  digitalWrite(CSPin, HIGH);  // disable slave select
  digitalWrite(CSPin, LOW); //ensure SS stays low
    SPI.transfer (0x01);//write to FR1 (Function Register 1)
    SPI.transfer (0xD0);
    SPI.transfer (0x02); //write to FR2 (Function Register 2)
    SPI.transfer (0xA0);
    SPI.transfer (0x03);//write to CFR (Channel Function Register)
    SPI.transfer (0x04);
  SPI.transfer (0x04); //write to CFTW0 (channel frequency tuning word 0) 80MHz
  SPI.transfer (0x28);
  SPI.transfer (0xF5);
  SPI.transfer (0xC2);
  SPI.transfer (0x8F);
  digitalWrite(CSPin, HIGH);// disable slave select
  } // end of setup
void loop (void)
  //do nothing
  } // end of loop
I believe this should output a single tone frequency of 80MHz.
Thank-you,
Care
