AD9833 register calculations (frequency)
Question asked by AlanGC on Apr 25, 2016
Latest reply on Apr 28, 2016 by mcee
Hi All
I'm trying to interface AD9833 to 18F452 , the hardware works fine. If I use your calculator link and send the hex code
you suggest then all works fine and accurate. I'm using a 25 Mhz clock to the device.
AD9833 Device Configuration Assistant | Design Center | Analog Devices
My problem is that I'm making an error in the calculation or there is a bug in my complier. I followed your application note AN1070 and my calculation was the same, but higher frequency give a massive error.
Could you show me how your calculator arrives at  2100 5C29 4A3D 9C29 8A3D C000 E000 2000 for a 4MHZ output @ 25Mhz. Im only interested 5C29 4A3D 9C29 8A3D for Frequency register 0 say.
AN1070 gives a simple example , could you repeat this for 4MHZ ?
Thanks in Advance.
Alan
