adv7280-M clock problem
Question asked by savva on Apr 18, 2016
Latest reply on Sep 21, 2016 by savva
Hi All.
We use adv7280-M chip for our custom board. I am working on Linux driver integration for this chip.
And I started with clock testing.
I use crystal test script first:
42 0F 00; # Exit Power Down Mode ADV7182 writes begin
42 03 0C;
42 1D 40;
42 13 00; #Power up INTRQ pads etc
42 0E 20; //access
42 40 D5;
42 48 80;
42 0E 00; #Program interrupt pin to drive low
As result I can see clock on XTAL pins, but INTRQ pin has high level still. As I understand, I have clock initialization fail.
After that I tried intialization script to output video stream on MIPI-CSi2 interface
##CVBS AUTODETECT##
:AUTODETECT CVBS Single Ended In Ain 1, MIPI Out:
delay 10 ;
42 0F 00 ; Exit Power Down Mode
42 00 00 ; INSEL = CVBS in on Ain 1
42 0E 80 ; ADI Required Write
42 9C 00 ; ADI Required Write
42 9C FF ; ADI Required Write
42 0E 00 ; Enter User Sub Map
42 03 4E ; ADI Required Write
42 04 57 ; Power-up INTRQ pin
42 13 00 ; Enable INTRQ output driver
42 17 41 ; select SH1
42 1D C0 ; Tri-State LLC output driver
42 52 CD ; ADI Required Write
42 80 51 ; ADI Required Write
42 81 51 ; ADI Required Write
42 82 68 ; ADI Required Write
42 FE 88 ; Set CSI Map Address
88 DE 02 ; Power up MIPI D-PHY
88 D2 F7 ; ADI Required Write
88 D8 65 ; ADI Required Write
88 E0 09 ; ADI Required Write
88 2C 00 ; ADI Required Write
88 00 00 ; Power up MIPI CSI-2 Tx
End
As result I can see digital sygnal on D0P and D0N pins but can`t see MIPI CLK sygnal. on CLK P and CLK N pins
I checked sygnal on XTAL. It is 28.63636 MHz.
Can anybody give me advice, what could be wrong in my initialization. As I understand I have fail with my clock initialization, but why I can see sygnal on MIPI interface. May be any register, where I can read error status or anything like that.
Thanks.
