ADUC832- Flash data corrupted byte
Question asked by FreddyS on Apr 18, 2016
Latest reply on Apr 20, 2016 by MMA
Hello
Using the ADUC832BSZ62-5
ESS Test were performed
Procedure:
System is ON.
Cooling up to -54 deg and then switching OFF.
Switch back to ON after some
time.
Problem:
Program fails at startup during boot sequence : Check sum error/
Preforming program FLASH memory damp revealed that one byte of the program flash memory was corrupted.
Note:
Reprogramming the flash brings back the good value to this byte. System is again well operating
Question:
Is this behavior normal when operated at such temperature?
What is the probability of such events to occurs under such conditions.
From about 100 cards tested, this happened in one of the cards
Thanks
Freddy
