Can the ADXL362 interrupt on acticity/inactivity on z-axis only?
Question asked by Naji on Apr 15, 2016
Latest reply on Apr 28, 2016 by STallur
I am using the ADXL362 to detect a tilt angle in the z-axis only. I don't care about x or y axes. I need to utilize the thresholds to minimize battery drain.
I want the INT1 to detect that I am below the threshold, and INT2 above a threshold.
What I see is that INT1 is always low and INT2 is always high.
Does the Activity/Inactivity threshold depend on all 3 axes?
I need the ADXL362 to be asleep until the thresholds are triggered to save battery power.
Am I using the right device?
Here is my code:
sendADXL362Word (WRITE, THRESH_ACT_L,  0x14, 0x01);
sendADXL362Word (WRITE, THRESH_INACT_L, 0xE8, 0x01);
// ACT_EN=INACT_EN=1, LOOP_MODE=11
sendADXL362Byte (WRITE, ACT_INACT_CR, 0x35);
// Set up INT1 to be Active Threshold active-high interrupt output
sendADXL362Byte (WRITE, INTMAP1, 0x10);
// Set up INT1 to be Inactive Threshold active-high interrupt output
sendADXL362Byte (WRITE, INTMAP2, 0x20);
// LOW_NOISE=01, AutoSleep=1, MEASURE=10
sendADXL362Byte (WRITE, POWER_CTL, 0x16);
