Errors when using gr_modtool
Question asked by vshn on Apr 15, 2016
Latest reply on Apr 16, 2016 by vshn
Hey I'm running a Linaro build on the ZedBoard. I am attempting to make custom gnu radio blocks but am receiving errors when using the gr_modtool create command. I checked to make sure that the libgnuradio-pmt-3.7.4git.so.0.0.0 is in my $PATH variable. Has anyone come across the issue or know what the root cause could be?
GNU Radio was built on the platform following the ANALOG guide. Thanks.
$ gr_modtool create fpga_accelerators
Traceback (most recent call last):
  File "/usr/local/bin/gr_modtool", line 25, in <module>
    from gnuradio.modtool import *
  File "/usr/local/lib/python2.7/dist-packages/gnuradio/modtool/__init__.py", line 25, in <module>
    from modtool_base import ModTool, ModToolException, get_class_dict
  File "/usr/local/lib/python2.7/dist-packages/gnuradio/modtool/modtool_base.py", line 27, in <module>
    from gnuradio import gr
  File "/usr/local/lib/python2.7/dist-packages/gnuradio/gr/__init__.py", line 41, in <module>
    from runtime_swig import *
  File "/usr/local/lib/python2.7/dist-packages/gnuradio/gr/runtime_swig.py", line 26, in <module>
    _runtime_swig = swig_import_helper()
  File "/usr/local/lib/python2.7/dist-packages/gnuradio/gr/runtime_swig.py", line 22, in swig_import_helper
    _mod = imp.load_module('_runtime_swig', fp, pathname, description)
ImportError: libgnuradio-pmt-3.7.4git.so.0.0.0: cannot open shared object file: No such file or directory
