FreedomSabre
HMC703
Discussion created by FreedomSabre on Apr 13, 2016
Latest reply on Apr 13, 2016 by FreedomSabre
i use hmc703 , ref=100M pfd=10M  output  2G~3G  integer mode
the loop filter i designed by adisimpll
but when i try to lock the frequency  , i need divde the rf signal  from VCO to pfd by 2 then it can lock ,in this situation ,just like i use pfd=5M to lock
2G~3G is below 4G ,i read the datasheet  it does not need to divide by  2
the last time  i encounter the same problem  ,i try to lock  400M ,it also need divide   rf signal  from VCO to pfd by 2
RF Divider Range
>4GHz Integer Mode 16 bit , Even values only 32 131,070
< 4GHz Integer Mode 16 bit , All values 16 65,535
