handling pins of ADV8005
Question asked by Kikka on Apr 12, 2016
Latest reply on Apr 13, 2016 by Kikka
Hello.
I have some questions how to handle pins of ADV8005.
1. ARC1_OUT(B7), ARC2_OUT(A7)
UG-707 says : Connect this pin to ground through a 4.7kΩ resistor if unused
The schematic of EVAL-ADV8005-SMZ says : Open
Which is correct?
2. HEAC_1+(M22), HEAC_1-(M23), HEAC_2+(V22), HEAC_2-(V23)
Which is correct?
3. N23 pin
Datasheet says : AVDD3(HDMI Tx1 Analog Power Supply (1.8 V))
UG-707 says : Connect this pin to ground.
Which is correct?
4. W23 pin
Datasheet says : AVDD4(HDMI Tx2 Analog Power Supply (1.8 V))
UG-707 says : Float this pin
Which is correct?
5. REF_CLK(C14), REF_HS(D14), REF_VS(D15)--from datasheet.
UG-707 says : these pins are NC.
Which is correct?
Thank you in advance.
Best regards.
Kikka
