TxRx Timing with Filter Enabled
Question asked by cy92612 on Apr 12, 2016
Latest reply on Jun 13, 2016 by tlili
I just updated to the latest No-OS driver and noticed the following comment in ad9361.c:
/* The FIR filter once enabled causes the interface timing to change.
* It's typically not a problem if the timing margin is big enough.
* However at 61.44 MSPS it causes problems on some systems.
* So we always run the digital tune in case the filter is enabled.
* If it is disabled we restore the values from the initial calibration.
I haven't been using the FIR filter, but will need to.  I've designed the FPGA to meet the published timing specs for the 2 Rx/2 Tx mode.  Are the timing numbers different than the datasheet values once the filter is enabled?
CYoung
