AD9858 SPI Interface
Question asked by Dorney on Jul 12, 2011
Latest reply on Jul 13, 2011 by Dorney
Hello All,
I am working with an AD9858 DDS, specifically the "DDS DAC Output Evaluation Board. To control the frequency I am trying to use an ATmega328 micro-controller programmed in AVR Studio.
I have checked the SPI sck and mosi outputs using an oscilloscope, seems to be working fine. The clock reference is 1Ghz at -5dBm. All other settings can be seen in the code below (also attached to avoid any formatting issues). Despite my continued efforts the DDS will not spit out the 60MHz I want it to.
Does anyone have their own SPI code for interfacing uC and AD9858 that they are willing to share?
Is there something else I am missing?
Thanks!
void
spi_setup()
DDRB = 0b00101101;
SPCR= 0b01010000;
int
spi_transmit(int data_byte)
SPDR=data_byte;
while(!(SPSR & (1<<SPIF)));
return SPDR;
void
FUD_Toggle()
PORTD = (1<<PD2);
_delay_ms(5000);
PORTD = (0<<PD2);
//-----------------Main Program--------------------------------------
int
main(void){
while(1){
DDRD = 0b11111110;
if (bit_is_set(PIND, PD0))
PORTD=(1<<PD1); //Put an LED here
_delay_ms(5000); //Use this delay time to set PD0 low (a switch)
PORTD=(0<<PD1);
PORTD=(1<<PD3); //Toggle the reset line
_delay_ms(5000);
PORTD=(0<<PD3);
PORTD=(0<<PD4); //Set PS0 to low
PORTD=(0<<PD5); //Set PS1 to low
PORTD=(0<<PD6); //Set SPSelect to low
PORTD=(0<<PD7); //Set CS to low
spi_setup();
spi_transmit(0b00000000); //CFR ADDR
//_delay_ms(5000);
FUD_Toggle();
spi_transmit(0b00000000); //4 byte CFR
//_delay_ms(5000);
//_delay_ms(5000);
//_delay_ms(5000);
spi_transmit(0b01011010);
//_delay_ms(5000);
FUD_Toggle();
spi_transmit(0b00000011);//FTW ADDR
//_delay_ms(5000);
FUD_Toggle();
spi_transmit(0b00001111);//4 byte FTW
//_delay_ms(5000);
spi_transmit(0b01011100);
//_delay_ms(5000);
spi_transmit(0b00101000);
//_delay_ms(5000);
spi_transmit(0b11110110);
//_delay_ms(5000);
FUD_Toggle();
PORTD=(1<<PD1); //Signals the end of SPI transmissions
_delay_ms(5000);
PORTD=(0<<PD1);
