AD7147 as a capacitance measuring instrument
Question asked by Ago on Apr 7, 2016
Latest reply on Aug 8, 2016 by Maurice
I am using AD7147 to read different capacitor values. I'm using Arduino UNO for the IC programming.
I have no particular requirements for the power settings, but I need the maximum resolution and full scale range.
Do I have to setup some particular register?
Moreover, i'm using the I2C comunication without the INT pin. There are some problems with this configuration?
I'm using the register settings in the following code.
#include <Wire.h>
#include "AD7147RegMap.h"
#define device 0B0101100    // device address
//variables
short unsigned int adLSB=0;
short unsigned int adMSB=0;
short unsigned int LSBi=0;
short unsigned int MSBi=0;
short unsigned int LSB=0;
short unsigned int MSB=0;
unsigned int i1=0;
unsigned int i2=0;
unsigned int i3=0;
unsigned int c1=0x0010;
unsigned int c2=0x0010;
unsigned int c3=0x0010;
unsigned int cella=0;
unsigned int I2Cdata;
unsigned int t0=0;
unsigned int t1=0;
unsigned int test=0;
int i=0;
//__________________________________________SETUP
void setup() {
// comunication setup
  Serial.begin(115200);
  Wire.begin(); // join i2c bus (address optional for master);
/////// CAPACITIVE SENSOR AD7147 STAGE SET UP  //
    writeI2C(PWR_CONTROL,0b0000010000000000);//reset
//// setup My configuration
    writeI2C(PWR_CONTROL,0x0000); // 1 stage
    writeI2C(STAGE_CAL_EN,0x0001);// enable calibration of 1 stages
    writeI2C(AMB_COMP_CTRL1,0b0000000101100100);
    writeI2C(AMB_COMP_CTRL0,0x32FB);
    writeI2C(AMB_COMP_CTRL1,0x4FF);
    writeI2C(AMB_COMP_CTRL2,0x832);//
    // STAGE 0 CIN 0_________________________________________________________________
   writeI2C(STAGE0_CONNECTION6_0,0xFFFF);
   writeI2C(STAGE0_CONNECTION12_7,0x3FFF);
   writeI2C(STAGE0_AFE_OFFSET,0x0000);
writeI2C(STAGE0_CONNECTION6_0,0x7FFE);
writeI2C(STAGE0_CONNECTION12_7,0x0FFF);
writeI2C(STAGE0_SENSITIVITY,0x0000);
writeI2C(STAGE0_OFFSET_LOW,0x0000);
writeI2C(STAGE0_OFFSET_HIGH,0x0000);
writeI2C(STAGE0_OFFSET_LOW_CLAMP,0x0000);
writeI2C(STAGE0_OFFSET_HIGH_CLAMP,0x0000);
writeI2C( STAGE0_FF_WORD0,0x0000);//          0x0E1
writeI2C( STAGE0_FF_WORD1,0x0000);//          0x0E2
writeI2C( STAGE0_FF_WORD2,0x0000);//          0x0E3
writeI2C( STAGE0_FF_WORD3,0x0000);//          0x0E4
writeI2C( STAGE0_FF_WORD4,0x0000);//          0x0E5
writeI2C( STAGE0_FF_WORD5,0x0000);//          0x0E6
writeI2C( STAGE0_FF_WORD6,0x0000);//          0x0E7
writeI2C( STAGE0_FF_WORD7,0x0000);//          0x0E8
writeI2C( STAGE0_SF_WORD0,0x0000);//          0x0E9
writeI2C( STAGE0_SF_WORD1,0x0000);//          0x0EA
writeI2C( STAGE0_SF_WORD2,0x0000);//          0x0EB
writeI2C( STAGE0_SF_WORD3,0x0000);//          0x0EC
writeI2C( STAGE0_SF_WORD4,0x0000);//          0x0ED
writeI2C( STAGE0_SF_WORD5,0x0000);//          0x0EE
writeI2C( STAGE0_SF_WORD6,0x0000);//          0x0EF
writeI2C( STAGE0_SF_WORD7,0x0000);//          0x0F0
writeI2C( STAGE0_SF_AMBIENT,0x0000);//        0x0F1
writeI2C( STAGE0_FF_AVG,0x0000);//            0x0F2
writeI2C( STAGE0_PEAK_DETECT_WORD0,0x0000);// 0x0F3
writeI2C( STAGE0_PEAK_DETECT_WORD1,0x0000);// 0x0F4
writeI2C( STAGE0_MAX_WORD0,0x0000);//         0x0F5
writeI2C( STAGE0_MAX_WORD1,0x0000);//         0x0F6
writeI2C( STAGE0_MAX_WORD2,0x0000);//         0x0F7
writeI2C( STAGE0_MAX_WORD3,0x0000);//         0x0F8
writeI2C( STAGE0_MAX_AVG,0x0000);//           0x0F9
writeI2C( STAGE0_HIGH_TRESHOLD,0x0000);//     0x0FA
writeI2C( STAGE0_MAX_TEMP,0x0000);//          0x0FB
//__________________________________________MAIN
void loop()
  t0=micros();
  c1=readI2C(0x00B);
  Serial.println(c1);
//__________________________________________function READ
unsigned int readI2C(unsigned int address)
Wire.beginTransmission(device);
   adMSB=address >> 8 ;
   adLSB=address & 0xFF ;
   Wire.write(adMSB);
   Wire.write(adLSB);
Wire.endTransmission();
Wire.requestFrom(device, 2);
  while(Wire.available())
   MSBi = Wire.read();
   LSBi = Wire.read();
  I2Cdata = LSBi |(MSBi  << 8 ) ;
  return(I2Cdata);
//__________________________________________function WRITE
unsigned int  writeI2C(unsigned int address,unsigned int data)
   MSB=data >> 8 ;
   LSB=data & 0xFF ;
// address
   Wire.write(adMSB);             // 0x017=10111         // sends instruction byte
   Wire.write(adLSB);             // 0x017=10111         // sends instruction byte
//data
   Wire.write(MSB);             // 0x017=10111         // sends instruction byte
   Wire.write(LSB);             // 0x017=10111         // sends instruction byte
   delay(3);
