fullon mode and active mode switching
Question asked by hotkernel on Jul 9, 2011
Latest reply on Jul 20, 2011 by hotkernel
Hi,all
I have some trouble in the pll setting, and hope someone could help me,thanks.
I use the BF512F CPU, and the silicon revision is 0.1; In my application, the cpu should switch power mode between fullon mode and active mode.
I have test about 20 chips,most of the chips can enter to active mode and then go back to fullon mode.But there are two chips always going idle when calling bfrom_SysControl function.
I'm not sure if the code has some bugs or the chip's problem.The following is my code:
#include <blackfin.h>
#include <nBlackfin.h>
#define PLL_LOCKCNT_VAL_BOTH    0x4000
#define EBIU_SDBCTL_VAL_BOTH    (EBE | EBSZ_32 | EBCAW_9)
#define EBIU_SDBCTL_VAL_ACTIVE  (EBE | EBSZ_32 | EBCAW_9)
#define PLL_CTL_VAL_FULLON      (nBYPASS | nOUT_DELAY | nIN_DELAY | nPDWN | nSTOPCK | nPLL_OFF | DF | SET_MSEL(21))
#define PLL_DIV_VAL_FULLON      (SET_SSEL(4) | CSEL_DIV1)
#define VR_CTL_VAL_FULLON       (nSCKELOW | nWAKE | nPHYWE | CLKBUFOE | 0x00B0 | FREQ)
#define EBIU_SDGCTL_VAL_FULLON  (0x80000000 | 0x40000000 | SCTLE | PSS | TWR_1 | TRCD_3 | TRP_3 | TRAS_7 | PASR_ALL | CL_3)
#define EBIU_RDIV_VAL_FULLON    0x03b6
#define PLL_CTL_VAL_ACTIVE      (BYPASS | nOUT_DELAY | nIN_DELAY | nPDWN | nSTOPCK | PLL_OFF | DF | SET_MSEL(21))
#define PLL_DIV_VAL_ACTIVE      (SET_SSEL(1) | CSEL_DIV1)
#define EBIU_SDGCTL_VAL_ACTIVE  (0x80000000 | 0x40000000 | SCTLE | PSS | TWR_1 | TRCD_1 | TRP_1 | TRAS_3 | PASR_ALL | CL_3)
#define EBIU_RDIV_VAL_ACTIVE    0x013c
// bypass pll
void ActiveMode(void)
u32 sic0, sic1;
u16 div;
ADI_SYSCTRL_VALUES freq;
freq.uwPllCtl = PLL_CTL_VAL_ACTIVE;
//freq.uwPllDiv = PLL_DIV_VAL_ACTIVE;
freq.uwPllLockCnt = PLL_LOCKCNT_VAL_BOTH;
sic1 = *pSIC_IWR1;
sic0 = *pSIC_IWR0;                  // Save value of SIC_IWR1 & SIC_IWR0
*pSIC_IWR1 = 0x00000000;
*pSIC_IWR0 = 0x00000001;      // disable all the interrupt but pll wakeup
ssync();
  bfrom_SysControl(SYSCTRL_WRITE | SYSCTRL_EXTVOLTAGE | SYSCTRL_PLLCTL | SYSCTRL_LOCKCNT/* | SYSCTRL_PLLDIV*/,
                             &freq,
                             NULL);
*pSIC_IWR0 = sic0;
*pSIC_IWR1 = sic1;                  // Restore SIC_IWR1 & SIC_IWR0
ssync();
return;
// same sequence as active mode
void FullOnMode(void)
u32 sic0, sic1;
u16 div;
freq.uwPllCtl = PLL_CTL_VAL_FULLON;
//freq.uwPllDiv = PLL_DIV_VAL_FULLON;
sic1 = *pSIC_IWR1;
sic0 = *pSIC_IWR0;
ssync();
                           &freq,
                           NULL);
*pSIC_IWR0 = sic0;
*pSIC_IWR1 = sic1;
ssync();
return;
void ChangeSdramCfg(bool full)
u16 rdiv;
u16 bctl;
u32 gctl;
u16 read;
if (full)
       rdiv = EBIU_RDIV_VAL_FULLON;
       bctl = EBIU_SDBCTL_VAL_BOTH;
       gctl = EBIU_SDGCTL_VAL_FULLON;
else
       rdiv = EBIU_RDIV_VAL_ACTIVE;
       bctl = EBIU_SDBCTL_VAL_ACTIVE;
       gctl = EBIU_SDGCTL_VAL_ACTIVE;
while((*pEBIU_SDSTAT & SDCI) == 0){}
*pEBIU_SDSTAT |= SDEASE;         /* clear SDRAM EAB sticky error status (W1C) */
*pEBIU_SDRRC = rdiv;                    /* SDRAM Refresh Rate Control Register */
*pEBIU_SDBCTL = bctl;                  /* SDRAM Memory Bank Control Register */
*pEBIU_SDGCTL = gctl;                  /* SDRAM Memory Global Control Register */
ssync();
    u16 *pTmp = (u16*) 0x4;
    read = *pTmp;
    while((*pEBIU_SDSTAT & SDRS) == 1){} /* Finalize SDC initialization */
void EnterActiveMode(void)
ssync();
*pEBIU_SDGCTL |= SRFS;                    // Enable self-refresh on SDRAM
while(!(*pEBIU_SDSTAT & SDSRA));      // Wait For self refresh active
ActiveMode();                                       // pll setting sequence, active mode
//_EnterActiveAsm();                             // this assemble code can also work for most of the chips
ChangeSdramCfg(FALSE);                    // config sdram for active mode
void EnterFullOnMode(void)
ssync();
FullOnMode();                                      // pll setting sequence, fullon mode
ChangeSdramCfg(TRUE);                      // config sdram for fullon mode
void main(void)
// all the code are programmed to the internal flash, and boot up correctly
// I have checked all the chips,the silicon revision is 0.1
BlinkLed();              // all of the chip can turn on the led
EnterActiveMode();  // the two chips with problems awlays halted in this function when call bfrom_SysControl
Delay_ms(3000);
EnterFullOnMode();
while(1)
  asm("nop;");
// following is assemble function for active mode
#include <bfrom.h>
.import "bfrom.h";
#define SYS_MMR_BASE_512               0xFFC00000
#define SIC_IWR1_512                           0xFFC00164
#define SIC_IWR0_512                           0xFFC00124
#define PLL_DIV_512                             0xFFC00004
#define IWR1_DISABLE_ALL_512           0x00000000
#define IRQ_PLL_WAKEUP_512             0x00000001
#define PLL_CTL_VAL_LOPOW              0x0401  /* DF | SET_MSEL(2) */
#define PLL_LOCKCNT_VAL_LOPOW     0x4000
#define PLL_DIV_VAL_LOPOW               0x0001
#define IMM32_512(reg,val) reg##.H=hi(val); reg##.L=lo(val)
.global __EnterActiveAsm;
.section L1_code;
__EnterActiveAsm:
    link sizeof(ADI_SYSCTRL_VALUES)+2;
    [--SP] = (R7:0,P5:0);
    SP += -12;
      IMM32_512(P5,SIC_IWR1_512);                    /* Load SIC_IWR1 reg address      */
      R7 = IWR1_DISABLE_ALL_512;
      R6 = [P5];                                                    /* Save value of SIC_IWR1            */
      [P5] = R7;                                                    /* Wakeup disable all peripherals   */
      IMM32_512(P5,SIC_IWR0_512);                    /* Load SIC_IWR1 reg address      */
      R7 = IRQ_PLL_WAKEUP_512;
      R5 = [P5];                                                    /* Save value of SIC_IWR0       */
      [P5] = R7;                                                    /* PLL Wakeup Interrupt enable    */
      // Setting the PLL_CRL,PLL_LOCKCNT regs' value
      R0 = 0;
      R0.L = PLL_CTL_VAL_LOPOW;
      w[FP+-sizeof(ADI_SYSCTRL_VALUES)+offsetof(ADI_SYSCTRL_VALUES,uwPllCtl)] = R0;
      R0.L = PLL_LOCKCNT_VAL_LOPOW;
      w[FP+-sizeof(ADI_SYSCTRL_VALUES)+offsetof(ADI_SYSCTRL_VALUES,uwPllLockCnt)] = R0;
#if 0
      // write pll_div directly(silicon revision 0.0), and the chip i used was 0.1
      R0.L = PLL_DIV_VAL_LOPOW;
      IMM32_512(P5,PLL_DIV_512);
      w[P5] = R0;
      R0 = (SYSCTRL_EXTVOLTAGE | SYSCTRL_PLLCTL | SYSCTRL_LOCKCNT | SYSCTRL_WRITE );
#else
      // use the BFROM_SYSCONTROL function to set the pll_div
      w[FP+-sizeof(ADI_SYSCTRL_VALUES)+offsetof(ADI_SYSCTRL_VALUES,uwPllDiv)] = R0;
      // the first parameter of the BFROM_SYSCONTROL function
      R0 = (SYSCTRL_EXTVOLTAGE | SYSCTRL_PLLCTL | SYSCTRL_PLLDIV | SYSCTRL_LOCKCNT | SYSCTRL_WRITE );
#endif
      // the second parameter of the BFROM_SYSCONTROL function
      R1 = FP;
      R1 += -sizeof(ADI_SYSCTRL_VALUES);
      // the third parameter of the BFROM_SYSCONTROL function
      R2 = 0 (z);
      IMM32_512(P4,BFROM_SYSCONTROL);
      call(P4);
      [P5] = R5;       /* Restore SIC_IWR0 register */
      [P5] = R6;       /* Restore SIC_IWR1 register */
      SP += 12;
      (R7:0,P5:0) = [SP++];
      unlink;
      rts;
__EnterActiveAsm.end:
JStyle.
消息编辑者为:hotkernel
