Unable to write into SPORT transmit register TX
Question asked by Raghupathi_Kokkarakonda on Mar 30, 2016
Latest reply on May 3, 2016 by Jithul_Janardhanan
I have the following code, My intention is to check that the SPORT1_TX register is getting update with the value is assigned to it and data has to be transmitted and received in loop back mechanism. I am using BF537 EZ KIT.
IDE : CrossCore studio
   Syncronous_Serial_Communication.c
#include<cdefbf537.h>
#include<ccblkfn.h>
#include<sysreg.h>
#include <sys\exception.h>
#define TFS_DIV 15 // Refer HRM for calculation of TFSDIV register
#define TCLK_DIV 10 // Refer HRM for calculation of TCLKDIV register
#define RFS_DIV 15 // Refer HRM for calculation of RFSDIV register
#define RCLK_DIV 10 // Refer HRM for calculation of RCLKDIV register
void Init_PLL(void);
void Init_data(void);
void Init_INTRs(void);
void Init_Tx_DMA(void);
void Init_Rx_DMA(void);
void Sport_Init(void);
EX_INTERRUPT_HANDLER(SPORT1_DMA_TX_ISR);
EX_INTERRUPT_HANDLER(SPORT1_DMA_RX_ISR);
EX_INTERRUPT_HANDLER(SPORT1_core_TX_ISR);
EX_INTERRUPT_HANDLER(SPORT1_core_RX_ISR);
#define BUFF_SIZE 100 // No. of data to transfer
unsigned short Tx_BUFF[BUFF_SIZE];
unsigned short Rx_BUFF[BUFF_SIZE];
volatile int Tx_count, Rx_count;
void main()
  Init_PLL();
  Init_data();
  //Init_INTRs();
  #ifdef DMA_mode_operation
  Init_Tx_DMA();
  Init_Rx_DMA();
  #endif
  Sport_Init();
  *pSPORT1_TX = 0x1111;
  *pSPORT1_RCR1 |= RSPEN;
  *pSPORT1_TCR1 |= TSPEN;
  //while(~(*pSPORT1_STAT & 0x1)){};
  Rx_BUFF[Rx_count++] = *pSPORT1_RX;
void Init_PLL(void)
  unsigned long temp = *pSIC_IMASK;
  *pPLL_CTL = 0x2000;
  *pPLL_DIV = 0x0005;
  *pVR_CTL = 0x40DB;
  *pSIC_IMASK = 0x0;
  *pSIC_IWR |= 0x1;
  *pSIC_IMASK = temp;
  long i, j;
  for (i = 0; i < BUFF_SIZE; i++, j += 0x1111)
  Tx_BUFF[i] = j;
  register_handler(ik_ivg9, SPORT1_DMA_RX_ISR);
  register_handler(ik_ivg9, SPORT1_DMA_TX_ISR);
  #else
  register_handler(ik_ivg9, SPORT1_core_RX_ISR);
  register_handler(ik_ivg9, SPORT1_core_TX_ISR);
  #endif
  *pSIC_IAR0 |= 0x20000000;
  *pSIC_IAR1 |= 0x00000002;
  *pSIC_IMASK |= 0x00000180;
  *pDMA6_START_ADDR = Tx_BUFF;
  *pDMA6_X_COUNT = BUFF_SIZE;
  *pDMA6_X_MODIFY = 0x02;
  *pDMA6_Y_COUNT = 0x00;
  *pDMA6_Y_MODIFY = 0x00;
  *pDMA6_CONFIG = WDSIZE_16 | DI_EN | DMAEN;
  *pDMA5_START_ADDR = Rx_BUFF;
  *pDMA5_X_COUNT = BUFF_SIZE;
  *pDMA5_X_MODIFY = 0x02;
  *pDMA5_Y_COUNT = 0x00;
  *pDMA5_Y_MODIFY = 0x00;
  *pDMA5_CONFIG = WDSIZE_16 | DI_EN | WNR | DMAEN;
  *pSPORT1_TX = Tx_BUFF[Tx_count++];
  // Put the data in transmit_buf to transmit register
  if(Tx_count == BUFF_SIZE)
  *pSIC_IMASK &= 0xFFFFFEFF;
  Rx_BUFF[Rx_count++] = *pSPORT1_RX ;
  if(Rx_count == BUFF_SIZE)
  *pSIC_IMASK &= 0xFFFFFF7F;
  while(!(*pDMA6_IRQ_STATUS & DMA_DONE));
  *pDMA6_IRQ_STATUS = DMA_DONE ;
  while(!(*pDMA5_IRQ_STATUS & DMA_DONE));
  *pDMA5_IRQ_STATUS = DMA_DONE ;
  *pSPORT1_RCR1 &= ~RSPEN;
  /*SPORTx Transmit Configuration 1 Register (SPORTx_TCR1)*/
  *pSPORT1_TCR1 |= ITCLK; /*Internal Transmit Clock Select */
  *pSPORT1_TCR1 |= DTYPE_NORM; /* Data Formatting Type - Normal Operation */
  *pSPORT1_TCR1 |= TLSBIT; /* Transmit Bit Order - LSB */
  *pSPORT1_TCR1 |= ITFS; /* Internal Transmit Frame Sync Select */
  *pSPORT1_TCR1 |= TFSR; /* Transmit Frame Sync Required Select */
  *pSPORT1_TCR1 |= DITFS; // Matt Suggested
  /*SPORTx Transmit Configuration 2 Register (SPORTx_TCR2)*/
  *pSPORT1_TCR2 |= SLEN(15); /* SPORT TX Word Length (2 - 31) */
  //*pSPORT1_TCR2 |= TSFSE; /* Transmit Stereo Frame Sync Enable */
  //*pSPORT1_TCR2 |= TXSE; /* TX Secondary Enable */
  //*pSPORT1_TCR2 |= TRFST; /* Left/Right Order (1 = Right Channel 1st) */
  /*SPORTx Receive Configuration 1 Register (SPORTx_RCR1)*/
  *pSPORT1_RCR1 |= IRCLK; /* Internal Receive Clock Select */
  *pSPORT1_RCR1 |= DTYPE_NORM; /* Data Format Normal */
  *pSPORT1_RCR1 |= RLSBIT; /* Receive Bit Order */
  *pSPORT1_RCR1 |= RFSR; /* Internal Receive Frame Sync Select */
  *pSPORT1_RCR1 |= RCKFE; /* Clock Falling Edge Select */
  /*SPORTx Receive Configuration 2 Register (SPORTx_RCR2)*/
  *pSPORT1_RCR2 |= SLEN(15); /* SPORT RX Word Length (2 - 31) */
  //*pSPORT1_RCR2 |= RSFSE; /* RX Stereo Frame Sync Enable */
  //*pSPORT1_RCR2 |= RXSE; /* RX Secondary Enable */
  //*pSPORT1_RCR2 |= RRFST; /* Right-First Data Order */
  /*Note RFSDIV or TFSDIV must still be greater than or equal to SLEN.*/
  /*TSCLKx frequency = (SCLK frequency)/(2 x (SPORTx_TCLKDIV + 1))
  * RSCLKx frequency = (SCLK frequency)/(2 x (SPORTx_RCLKDIV + 1))*/
  *pSPORT1_TCLKDIV = TCLK_DIV;
  *pSPORT1_TFSDIV = TFS_DIV;
  *pSPORT1_RCLKDIV = RCLK_DIV;
  *pSPORT1_RFSDIV = RFS_DIV;
  *pPORT_MUX = PGTE|PGRE|PGSE;
  *pPORTG_FER = 0xFF00;
// *pSPORT1_TCR1 = (TFSR  | TLSBIT | ITFS | ITCLK);
// *pSPORT1_TCR2 |= SLEN(15);
// *pSPORT1_RCR1 = RFSR  | RLSBIT;
// *pSPORT1_RCR2 |= SLEN(15);
// *pSPORT1_TCLKDIV = TCLK_DIV;
// *pSPORT1_TFSDIV = TFS_DIV;
// *pSPORT1_RCLKDIV = RCLK_DIV;
// *pSPORT1_RFSDIV = RFS_DIV;
// *pPORT_MUX = PGTE|PGRE|PGSE;
// *pPORTG_FER = 0xFF00;
I connected , SPORT pin P10 -> pin12, and pin8 to pin 14.
Need help ASAP.
