ADF4360-7 vtune
Question asked by and on Mar 26, 2016
Latest reply on Apr 6, 2016 by rbrennan
I am currently using the ADF4360-7 as a programable signal source.
Is it possible to use the ADF4360-7 first to specify the frequency range by programming the device and afterwards as a VCO in a feed back loop externally modifying vtune?
Is this a normal operation mode?
How can the external control voltage be connected to vtune (pin 7).
In the current design vtune is connected to CP by a third order filter calculated by the software.
Do you perhaps have a application example for using the ADF4360 as a Integrated synthesizer and at the same time as a VCO?
Since I am new in this field the answer might by very simple.
Thanks a lot for your Help
AND
