ADL5202 abnormal peak at output
Question asked by katsu on Mar 25, 2016
Latest reply on Apr 7, 2016 by katsu
Issue:
When changing the amplitude
of input signal to certain value from zero, abnormal peak of a few period is observed at the beginning of output amplitude changing to certain value from zero.
Condition:
Gain is set by Parallel I/F transparent mode.
Gain is fixed to max.
Input signal is 128MHz sine wave.
Output level is 0dBm in 150 ohm.
Measured by FET probe contacting at 150 ohm termination (>>See the attachment please).
Application circuit:
Similar to Figure 55. Wideband ADC Interfacing Example Featuring One-Half of the ADL5202 and the AD9268 which is described in datasheet.
Request:
1. Could you please tell me the ways to solve this issue?
2. Could you please provide the transmission function of the internal ac-coupled feedback path? The feedback path is described in p.18 of datasheet. Would like to examine if excess compensation causes this issue.
Best Regards,
