VisualAnalog pattern saver
Question asked by K_consistant on Mar 22, 2016
Latest reply on Jul 27, 2016 by K_consistant
I am using HSC-ADC-EVALCZ with ADC.
I am saving captured data using pattern saver block, but I found the data is polled periodically. (0.7~0.8s)
I would like to capture and save data when external rising trigger is detected.
I was trying to control the rate with full signal which is connected to FFA and FFB at USB circuit since I store the data based on external trigger signal. However, it does not affect the data saving rate, it seems VisualAnalog pulls data in certain rate. (I found the address controlling block is not connected to main chip.)
Is there any way I can save captured data synchronized with external trigger signal? I can store it with external trigger, but cannot save every signal to the hard drive in the same time.
Thanks.
Younsu Kim
