AD9834 not working with MCLK above 33KHz?!
Question asked by Chimp on Mar 18, 2016
Latest reply on Mar 27, 2016 by LouijieC
Hello everyone
I'm trying to build a sine wave generator that goes from 20Hz to 30KHz with an arduino uno and the AD9834 DDS.
First I had problems with the SPI communication but got that fixed, thanks to the nice people on this forum, by changing the SPI mode from 0 to 2.
My current problem is that the DDS stops outputting a frequency when the MCLK frequency rises above 33KHz. I read on the internet that the minimum MCLK frequency should be 1MHz, but it just outputs a DC level that changes with different higher frequencies.
I've got a breadbord setup for testing (see picture below) and I'm using the build-in function generator of my Rigol scope to make the MCLK signal (bandwidth generator = 25MHz). I followed the data sheet and the schematic of the evaluation board to make the circuit.
A few questions that I have:
  • Is it possible to get this DDS working in a breadboard setup? (only to generate up to 30KHz)
  • Would it work if I build a clock generator with a crystal instead of using a function generator?
Any help or advice on this would be much appreciated.
Thank you!
Setup
Scope: MCLK = 30KHz, register0LSB = 0x50C7, register0MSB = 0x4000
Scope: MCLK = 30 KHz, register0LSB = 0x5037, register0MSB = 0x4337
Scope: MCLK = 1 MHz, register0LSB = 0x5037, register0MSB = 0x4337
Arduino Code
#include <SPI.h>
const int slaveSelect = 8;
void setup()
  SPI.begin();
  SPI.beginTransaction(SPISettings(100000, MSBFIRST, SPI_MODE2));
  pinMode(slaveSelect, OUTPUT);
  digitalWrite(slaveSelect, HIGH);
  delayMicroseconds(10);
  AD9834_init();
void loop()
void AD9834_init(void)
  digitalWrite(slaveSelect, LOW);
  SPI.transfer16(0x2100); // control word, set output to mid value voltage      RESET = 1
  SPI.transfer16(0x5037); // Frequency Register 0 LSB
  SPI.transfer16(0x4337); // Frequency Register 0 MSB
  SPI.transfer16(0xC000); // phase offset of freq0 = 0
  SPI.transfer16(0x2000); // control word, set output = sine  wave      RESET = 0
