How to view imask and lirptl register in visual dsp
Question asked by DSPprogrammer on Jul 6, 2011
Latest reply on Jul 12, 2011 by jeyanthi.jegadeesan
I try to mask and unmask serial port interrupts on a ADSP21363 and ADSP21262.
To do so I use the following instructions:
Masking all six serial port:
sysreg_bit_clr_nop(sysreg_LIRPTL, SP0IMSK);
sysreg_bit_clr_nop(sysreg_LIRPTL, SP2IMSK);
sysreg_bit_clr_nop(sysreg_LIRPTL, SP4IMSK);
sysreg_bit_clr_nop(sysreg_IMASK,  SP1I);
sysreg_bit_clr_nop(sysreg_IMASK,  SP3I);
sysreg_bit_clr_nop(sysreg_IMASK,  SP5I);
Unmasking all six serial ports
sysreg_bit_set_nop(sysreg_LIRPTL, SP0IMSK);
sysreg_bit_set_nop(sysreg_LIRPTL, SP2IMSK);
sysreg_bit_set_nop(sysreg_LIRPTL, SP4IMSK);
sysreg_bit_set_nop(sysreg_IMASK,  SP1I);
sysreg_bit_set_nop(sysreg_IMASK,  SP3I);
sysreg_bit_set_nop(sysreg_IMASK,  SP5I);
Now I want to verify that the masking / unmasking works as expected. To do so I use the HPUSB emulator and single step the mentioned instructions.
I then view the registers imask and lirptl in the "interrupts register" window of visual dsp.
When I step I do not see any change in the registers. When I change the bits by hand in the interrupts registers window, the register values change as expected.
While single stepping I have set "Mask interrupts during step" in the Target Options window.
Could somebody explain why is that?
Is this a bug in my code, a bug in visual dsp or is it an expected behaviour?
Thank you very much
Stefan
