CCES pin Multiplexing bug with ethernet driver ?
Question asked by pfeifferc on Mar 11, 2016
Latest reply on Apr 27, 2016 by Kader.M
Hi !
I use a own board based on BF607 and a Micrel Switch connected via ETH0. / CCES2.1.0
This part communicate with SPI and I use SPI1 for this purpose.
After setup PinMux via PinMulitplexing Wizard
pREG_PORTD_FER is set to 0xffff (all functions used)
in ADI_PHY_RESULT KSZ8795_phy_init function (derived from adi_dp83848_phy.c) there is a code section
which set FER_CLR reg by an or conjunction:
   *pREG_PORTD_FER_CLR  |= BITM_PORT_FER_CLR_PX0  ;
    *pREG_PORTD_DIR_CLR  |= BITM_PORT_DIR_CLR_PX0  ;
    *pREG_PORTD_INEN_SET |= BITM_PORT_INEN_SET_PX0 ;
    *pREG_PORTD_POL_SET  |= BITM_PORT_POL_SET_PX0  ;
this first and 2nd instruction clr all FER and DIR states -> as a result the pins are all GPIO after this ->SPI no longer working
I modify this by set the CLR/DIR_CLR reg only with the requested PIN !
(FER_CLR and DIR_CLR regs are set to 0x0000FFFF after adi_initComponents - without manual manipulation)
kind regards chris
