Building axi_i2s_adi issues
Question asked by Ronen on Mar 11, 2016
Latest reply on Mar 11, 2016 by Ronen
Branched from an earlier discussion
Is this error can cause that problems?
This error occured when i built the library(axi_i2s_adi) from hdl-master (and I also tried 2015_r1 version too)
I attach the error message in vivado
---------------------------------------------------ERROR MESSAGE ----------------------------------------------------------------
ERROR: [IP_Flow 19-395] Problem validating against XML schema: Unexpected empty element spirit:physicalPort
# adi_add_bus_clock "DMA_REQ_RX_ACLK" "DMA_REQ_RX:DMA_ACK_RX" "DMA_REQ_RX_RSTN"
ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
    while executing
"set_property display_name $reset_inf_name $reset_inf"
    invoked from within
"if { $reset_signal_name != "" } {
  set assoc_reset [ipx::add_bus_parameter "ASSOCIATED_RESET" $clock_inf]
  set_property value $reset_signal_name $as..."
    (procedure "adi_add_bus_clock" line 14)
    invoked from within
"adi_add_bus_clock "DMA_REQ_RX_ACLK" "DMA_REQ_RX:DMA_ACK_RX" "DMA_REQ_RX_RSTN""
    (file "./axi_i2s_adi_ip.tcl" line 43)
