AD9250 Subclass 1 LMFC offset resets jesd output data
Question asked by sam_thales_uk on Mar 8, 2016
Latest reply on Apr 21, 2016 by J.Harris
I'm currently trying to interface the jesd204b on the AD9250 with an Arria V SOC FPGA.
The jesd204b serial interface is working fine on subclass 0, and I can see the correct digital data coming though.
The problems comes when I use subclass 1. I'm sending a periodic sysref to the ADC and FPGA. I'm writing 0x1 and 0x3 to register 0x3A like on the datasheet. If I do only this I don't get any data coming though. The only way I get data through is if I write 0x8 or 0xA or 0xC or 0xE to register 0x8B.
The issue then is the digital output I get from the ADC. I get the correct data but every time after some samples, the ADC stops outputing data for a couple of hundreds of clock cycles and then starts outputing correct data and then stop again.... I've attached a screenshot of the output to show.
Why is it doing that ? How can I solve this problem ?
Thanks in advance
