What does cf_axi_dds 74204000.axi_ad9122: DRP unlocked mean?
Question asked by EdwardK on Mar 8, 2016
Latest reply on Mar 8, 2016 by EdwardK
I have a transmitter only design based on fmcomms1:
analogdevicesinc/hdl branch hdl_2015_r1 Vivado 2014.4.1
kernel xcomm_zynq 2eebbcd6c1f2461fb1aedcd52e6c03ecfa3c4746
What does "[0.915698] cf_axi_dds 74204000.axi_ad9122: DRP unlocked." mean?
A) dmesg
   [0.714754] bus: 'spi': add driver ad9523
   [0.714779] bus: 'spi': driver_probe_device: matched device spi1.3 with driver ad9523
   [0.714788] bus: 'spi': really_probe: probing driver ad9523 with device spi1.3
   [0.714837] ad9523 spi1.3: no default pinctrl state
   [0.714991] ad9523 spi1.3: Looking up vcc-supply from device tree
   [0.715005] ad9523 spi1.3: Looking up vcc-supply property in node /amba_pl/axi_quad_spi@41e00000/ad9523-lpc@3 faild
   [0.715012] spi1.3 supply vcc not found, using dummy regulator
   [0.750746] device: 'iio:device1': device_add
   [0.750947] bus: 'iio': add device iio:device1
   [0.751119] ad9523 spi1.3: probed ad9523-lpc
   [0.754022] driver: 'ad9523': driver_bound: bound to device 'spi1.3'
   [0.813384] bus: 'platform': driver_probe_device: matched device 74204000.axi_ad9122 with driver cf_axi_dds
   [0.813393] bus: 'platform': really_probe: probing driver cf_axi_dds with device 74204000.axi_ad9122
   [0.813415] cf_axi_dds 74204000.axi_ad9122: no default pinctrl state
B) sysfs @ boot
   out_altvoltage0_ZD_OUTPUT_frequency:122880000
   out_altvoltage0_ZD_OUTPUT_phase:0.000000
   out_altvoltage0_ZD_OUTPUT_raw:1
   out_altvoltage11_NB_LO_REF_CLK_frequency:122880000
   out_altvoltage11_NB_LO_REF_CLK_phase:0.000000
   out_altvoltage11_NB_LO_REF_CLK_raw:1
   out_altvoltage12_DAC_CLK_frequency:491520000
   out_altvoltage12_DAC_CLK_phase:0.000000
   out_altvoltage12_DAC_CLK_raw:1
   out_altvoltage13_DAC_DCO_CLK_frequency:245760000
   out_altvoltage13_DAC_DCO_CLK_phase:0.000000
   out_altvoltage13_DAC_DCO_CLK_raw:1
   out_altvoltage5_WB_LO_REF_CLK_frequency:122880000
   out_altvoltage5_WB_LO_REF_CLK_phase:0.000000
   out_altvoltage5_WB_LO_REF_CLK_raw:1
   out_altvoltage9_DAC_REF_CLK_frequency:30720000
   out_altvoltage9_DAC_REF_CLK_phase:0.000000
   out_altvoltage9_DAC_REF_CLK_raw:1
   pll1_locked:1
   pll1_reference_clk_a_present:0
   pll1_reference_clk_b_present:1
   pll1_reference_clk_test_present:0
   pll2_feedback_clk_present:1
   pll2_locked:1
   pll2_reference_clk_present:1
C) sysfs manual corrections and status
   out_altvoltage13_DAC_DCO_CLK_frequency:491520000
   out_altvoltage9_DAC_REF_CLK_frequency:61440000
   pll1_locked:1
   pll2_locked:1
D) cd /sys/bus/platform/drivers/cf_axi_dds && echo 74204000.axi_ad9122 > bind
   [232.643226] cf_axi_dds 74204000.axi_ad9122: no default pinctrl state
   [232.739430] cf_axi_dds 74204000.axi_ad9122: DRP unlocked.
   [232.739468] cf_axi_dds: probe of 74204000.axi_ad9122 failed with error -110
E) Device tree
   &axi_ad9122_dma {
    compatible = "adi,axi-dmac-1.00.a";
    #dma-cells = <1>;
    clocks = <&clkc 16>;
    dma-channel {
    adi,buswidth = <64>;
    adi,type = <1>;
    adi,cyclic;
   &axi_ad9122 {
    compatible = "adi,axi-ad9122-6.00.a";
    reg = <0x74204000 0x10000>;
    spibus-connected = <&dac_ad9122>;
    dmas = <&axi_ad9122_dma 0>;
    dma-names = "tx";
    dac-sample-frequency = <400000000>;
    xlnx,dphase-timeout = <0x8>;
    xlnx,num-mem = <0x1>;
    xlnx,num-reg = <0x1>;
    xlnx,s-axi-min-size = <0x1ff>;
    xlnx,slv-awidth = <0x20>;
    xlnx,slv-dwidth = <0x20>;
    xlnx,use-wstrb = <0x0>;
   &axi_quad_spi_0 {
    #address-cells = <1>;
    #size-cells = <0>;
    clk0_ad9523: ad9523-lpc@3 {
    #size-cells = <0>;
    #clock-cells = <1>;
    compatible = "ad9523-1";
    reg = <0x3>;
    spi-max-frequency = <10000000>;
    /*spi-3wire;*/
    clock-output-names = "ad9523-lpc_out0", "ad9523-lpc_out1", "ad9523-lpc_out2", "ad9523-lpc_out3", "ad9523-lpc_out4", "ad9523-lpc_out5", "ad9523-lpc_out6", "ad9523-lpc_out7", "ad9523-lpc_out8", "ad9523-lpc_out9", "ad9523-lpc_out10", "ad9523-lpc_out11", "ad9523-lpc_out12", "ad9523-lpc_out13";
    adi,vcxo-freq = <122880000>;
    adi,refb-diff-rcv-enable;
    adi,zd-in-diff-enable;
    adi,osc-in-cmos-neg-inp-enable;
    adi,refa-r-div = <0>;
    adi,refb-r-div = <0>;
    adi,pll1-feedback-div = <4>;
    adi,pll1-charge-pump-current-nA = <2000>;
    adi,refa-cmos-neg-inp-enable;
    adi,pll1-loop-filter-rzero = <3>;
    adi,ref-mode = <3>;
    adi,pll2-charge-pump-current-nA = <420000>;
    adi,pll2-ndiv-a-cnt = <0>;
    adi,pll2-ndiv-b-cnt = <3>;
    adi,pll2-freq-doubler-enable;
    adi,pll2-r2-div = <1>;
    adi,pll2-vco-diff-m1 = <3>;
    adi,pll2-vco-diff-m2 = <3>;
    adi,rpole2 = <0>;
    adi,rzero = <2>;
    adi,cpole1 = <2>;
    ad9523_0_c0:channel@0 {
    reg = <0>;
    adi,extended-name = "ZD_OUTPUT";
    adi,driver-mode = <2>;
    adi,divider-phase = <0>;
    adi,channel-divider = <8>;
    ad9523_0_c12:channel@12 {
    reg = <12>;
    adi,extended-name = "DAC_CLK";
    adi,driver-mode = <1>;
    adi,channel-divider = <2>;
    ad9523_0_c9:channel@9 {
    reg = <9>;
    adi,extended-name = "DAC_REF_CLK";
    adi,channel-divider = <16>;
    ad9523_0_c13:channel@13 {
    reg = <13>;
    adi,extended-name = "DAC_DCO_CLK";
    adi,driver-mode = <3>;
    ad9523_0_c5:channel@5 {
    reg = <5>;
    adi,extended-name = "WB_LO_REF_CLK";
    adi,driver-mode = <8>;
    adi,sync-ignore-enable;
    ad9523_0_c11:channel@11 {
    reg = <11>;
    adi,extended-name = "NB_LO_REF_CLK";
    dac_ad9122: dac-ad9122@0 {
    #size-cells = <0>;
    compatible = "ad9122";
    reg = <0x0>;
    clocks = <&clk0_ad9523 13>, <&clk0_ad9523 12>, <&clk0_ad9523 9>;
    clock-names = "data_clk", "dac_clk", "ref_clk";
    dac-fcenter-shift = <0>;
    dac-interp-factor = <2>;
    /*dac-data-rate = <491520000>;*/
    dac-data-rate = <245760000>;
    temp-sensor-calibration-temperature-mdeg = <25000>;
    fixed_lo_adf4350: fixed-lo-adf4350-tx@1 {
    #size-cells = <0>;
    compatible = "adf4350";
    reg = <0x1>;
    clocks = <&clk0_ad9523 11>;
    clock-names = "clkin";
    vcc-supply = <&fixed_3v_reg>;
    regulator-name = "vcc";
    adi,channel-spacing = <100000>;
    adi,power-up-frequency = <3030000000>;
    adi,gpio-lock-detect = <&axi_gpio_tx_ic 1 0>;
    adi,phase-detector-polarity-positive-enable;
    adi,charge-pump-current = <2500>;
    adi,muxout-select = <6>;
    adi,output-power = <3>;
    adi,mute-till-lock-enable;
    wb_lo_adf5355: wb-lo-adf5355-tx@2 {
    #clock-cells = <0>;
    gpios = <&axi_gpio_tx_ic 0 0>;
    compatible = "adf5355";
    reg = <0x2>;
    clocks = <&clk0_ad9523 5>;
    clock-output-names = "ADF5355";
    adi,charge-pump-current = <900>;
    adi,output-a-power = <3>;
    adi,output-b-power = <0>;
    adi,charge-pump-negative-bleed-enable;
    adi,reference-differential-input-enable;
    adi,power-up-frequency = /bits/ 64 <464000000>;
    adi,clock-shift = <2>;
    adi,reference-doubler-enable;
