AD9364 CLK_OUT and DATA_CLK disappearing shortly after successful initialization
Question asked by laobeylu on Mar 5, 2016
Latest reply on Mar 7, 2016 by tlili
I'm using an AD9364 connected to an Artix 7 FPGA on a custom board. The FPGA contains a MicroBlaze which runs the AD-provided No-OS AD9361 driver. I'm trying to use the AD9364 in FDD independent/pin control mode with the 2 port CMOS interface (running at 1.8V).
Initialization is successful, and the driver reports that the AD9364 is in the FDD independent state. The AD9364 is configured to output its clock on CLK_OUT.
However, about 300 ms after this apparently successful initialization, both CLK_OUT and DATA_CLK disappear. During this time no signals are sent to the AD9364 (ENABLE and TXNRX are low, to keep the signal chains disabled). Querying the state machine mode using ad9361_get_en_state_machine_mode still returns FDD independent mode. Reinitializing the AD9364 causes it to output the expected clock signals again, but still lasting only ~300 ms.
I have slightly modified the parameters, turning off interface tuning, enabling FDD independent mode and configuring the CMOS interface. All other parameters have not been modified.
AD9361_InitParam default_init_param = {
  /* Identification number */
  0, //id_no;
  /* Reference Clock */
  40000000UL, //reference_clk_rate
  /* Base Configuration */
  0, //two_rx_two_tx_mode_enable *** adi,2rx-2tx-mode-enable
  1, //one_rx_one_tx_mode_use_rx_num *** adi,1rx-1tx-mode-use-rx-num
  1, //one_rx_one_tx_mode_use_tx_num *** adi,1rx-1tx-mode-use-tx-num
  1, //frequency_division_duplex_mode_enable *** adi,frequency-division-duplex-mode-enable
  1, //frequency_division_duplex_independent_mode_enable *** adi,frequency-division-duplex-independent-mode-enable
  0, //tdd_use_dual_synth_mode_enable *** adi,tdd-use-dual-synth-mode-enable
  0, //tdd_skip_vco_cal_enable *** adi,tdd-skip-vco-cal-enable
  0, //tx_fastlock_delay_ns *** adi,tx-fastlock-delay-ns
  0, //rx_fastlock_delay_ns *** adi,rx-fastlock-delay-ns
  0, //rx_fastlock_pincontrol_enable *** adi,rx-fastlock-pincontrol-enable
  0, //tx_fastlock_pincontrol_enable *** adi,tx-fastlock-pincontrol-enable
  0, //external_rx_lo_enable *** adi,external-rx-lo-enable
  0, //external_tx_lo_enable *** adi,external-tx-lo-enable
  5, //dc_offset_tracking_update_event_mask *** adi,dc-offset-tracking-update-event-mask
  6, //dc_offset_attenuation_high_range *** adi,dc-offset-attenuation-high-range
  5, //dc_offset_attenuation_low_range *** adi,dc-offset-attenuation-low-range
  0x28, //dc_offset_count_high_range *** adi,dc-offset-count-high-range
  0x32, //dc_offset_count_low_range *** adi,dc-offset-count-low-range
  0, //tdd_use_fdd_vco_tables_enable *** adi,tdd-use-fdd-vco-tables-enable
  0, //split_gain_table_mode_enable *** adi,split-gain-table-mode-enable
  MAX_SYNTH_FREF, //trx_synthesizer_target_fref_overwrite_hz *** adi,trx-synthesizer-target-fref-overwrite-hz
  0, // qec_tracking_slow_mode_enable *** adi,qec-tracking-slow-mode-enable
  /* ENSM Control */
  0, //ensm_enable_pin_pulse_mode_enable *** adi,ensm-enable-pin-pulse-mode-enable
  0, //ensm_enable_txnrx_control_enable *** adi,ensm-enable-txnrx-control-enable
  /* LO Control */
  2400000000UL, //rx_synthesizer_frequency_hz *** adi,rx-synthesizer-frequency-hz
  2400000000UL, //tx_synthesizer_frequency_hz *** adi,tx-synthesizer-frequency-hz
  /* Rate & BW Control */
  {983040000, 245760000, 122880000, 61440000, 30720000, 30720000},//uint32_t rx_path_clock_frequencies[6] *** adi,rx-path-clock-frequencies
  {983040000, 122880000, 122880000, 61440000, 30720000, 30720000},//uint32_t tx_path_clock_frequencies[6] *** adi,tx-path-clock-frequencies
  18000000,//rf_rx_bandwidth_hz *** adi,rf-rx-bandwidth-hz
  18000000,//rf_tx_bandwidth_hz *** adi,rf-tx-bandwidth-hz
  /* RF Port Control */
  0, //rx_rf_port_input_select *** adi,rx-rf-port-input-select
  0, //tx_rf_port_input_select *** adi,tx-rf-port-input-select
  /* TX Attenuation Control */
  10000, //tx_attenuation_mdB *** adi,tx-attenuation-mdB
  0, //update_tx_gain_in_alert_enable *** adi,update-tx-gain-in-alert-enable
  /* Reference Clock Control */
  0, //xo_disable_use_ext_refclk_enable *** adi,xo-disable-use-ext-refclk-enable
  {8, 5920}, //dcxo_coarse_and_fine_tune[2] *** adi,dcxo-coarse-and-fine-tune
  CLKOUT_ENABLE, //clk_output_mode_select *** adi,clk-output-mode-select
  /* Gain Control */
  2, //gc_rx1_mode *** adi,gc-rx1-mode
  2, //gc_rx2_mode *** adi,gc-rx2-mode
  58, //gc_adc_large_overload_thresh *** adi,gc-adc-large-overload-thresh
  4, //gc_adc_ovr_sample_size *** adi,gc-adc-ovr-sample-size
  47, //gc_adc_small_overload_thresh *** adi,gc-adc-small-overload-thresh
  8192, //gc_dec_pow_measurement_duration *** adi,gc-dec-pow-measurement-duration
  0, //gc_dig_gain_enable *** adi,gc-dig-gain-enable
  800, //gc_lmt_overload_high_thresh *** adi,gc-lmt-overload-high-thresh
  704, //gc_lmt_overload_low_thresh *** adi,gc-lmt-overload-low-thresh
  24, //gc_low_power_thresh *** adi,gc-low-power-thresh
  15, //gc_max_dig_gain *** adi,gc-max-dig-gain
  /* Gain MGC Control */
  2, //mgc_dec_gain_step *** adi,mgc-dec-gain-step
  2, //mgc_inc_gain_step *** adi,mgc-inc-gain-step
  0, //mgc_rx1_ctrl_inp_enable *** adi,mgc-rx1-ctrl-inp-enable
  0, //mgc_rx2_ctrl_inp_enable *** adi,mgc-rx2-ctrl-inp-enable
  0, //mgc_split_table_ctrl_inp_gain_mode *** adi,mgc-split-table-ctrl-inp-gain-mode
  /* Gain AGC Control */
  10, //agc_adc_large_overload_exceed_counter *** adi,agc-adc-large-overload-exceed-counter
  2, //agc_adc_large_overload_inc_steps *** adi,agc-adc-large-overload-inc-steps
  0, //agc_adc_lmt_small_overload_prevent_gain_inc_enable *** adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable
  10, //agc_adc_small_overload_exceed_counter *** adi,agc-adc-small-overload-exceed-counter
  4, //agc_dig_gain_step_size *** adi,agc-dig-gain-step-size
  3, //agc_dig_saturation_exceed_counter *** adi,agc-dig-saturation-exceed-counter
  1000, // agc_gain_update_interval_us *** adi,agc-gain-update-interval-us
  0, //agc_immed_gain_change_if_large_adc_overload_enable *** adi,agc-immed-gain-change-if-large-adc-overload-enable
  0, //agc_immed_gain_change_if_large_lmt_overload_enable *** adi,agc-immed-gain-change-if-large-lmt-overload-enable
  10, //agc_inner_thresh_high *** adi,agc-inner-thresh-high
  1, //agc_inner_thresh_high_dec_steps *** adi,agc-inner-thresh-high-dec-steps
  12, //agc_inner_thresh_low *** adi,agc-inner-thresh-low
  1, //agc_inner_thresh_low_inc_steps *** adi,agc-inner-thresh-low-inc-steps
  10, //agc_lmt_overload_large_exceed_counter *** adi,agc-lmt-overload-large-exceed-counter
  2, //agc_lmt_overload_large_inc_steps *** adi,agc-lmt-overload-large-inc-steps
  10, //agc_lmt_overload_small_exceed_counter *** adi,agc-lmt-overload-small-exceed-counter
  5, //agc_outer_thresh_high *** adi,agc-outer-thresh-high
  2, //agc_outer_thresh_high_dec_steps *** adi,agc-outer-thresh-high-dec-steps
  18, //agc_outer_thresh_low *** adi,agc-outer-thresh-low
  2, //agc_outer_thresh_low_inc_steps *** adi,agc-outer-thresh-low-inc-steps
  1, //agc_attack_delay_extra_margin_us; *** adi,agc-attack-delay-extra-margin-us
  0, //agc_sync_for_gain_counter_enable *** adi,agc-sync-for-gain-counter-enable
  /* Fast AGC */
  64, //fagc_dec_pow_measuremnt_duration ***  adi,fagc-dec-pow-measurement-duration
  260, //fagc_state_wait_time_ns ***  adi,fagc-state-wait-time-ns
  /* Fast AGC - Low Power */
  0, //fagc_allow_agc_gain_increase ***  adi,fagc-allow-agc-gain-increase-enable
  5, //fagc_lp_thresh_increment_time ***  adi,fagc-lp-thresh-increment-time
  1, //fagc_lp_thresh_increment_steps ***  adi,fagc-lp-thresh-increment-steps
  /* Fast AGC - Lock Level */
  10, //fagc_lock_level ***  adi,fagc-lock-level
  1, //fagc_lock_level_lmt_gain_increase_en ***  adi,fagc-lock-level-lmt-gain-increase-enable
  5, //fagc_lock_level_gain_increase_upper_limit ***  adi,fagc-lock-level-gain-increase-upper-limit
  /* Fast AGC - Peak Detectors and Final Settling */
  1, //fagc_lpf_final_settling_steps ***  adi,fagc-lpf-final-settling-steps
  1, //fagc_lmt_final_settling_steps ***  adi,fagc-lmt-final-settling-steps
  3, //fagc_final_overrange_count ***  adi,fagc-final-overrange-count
  /* Fast AGC - Final Power Test */
  0, //fagc_gain_increase_after_gain_lock_en ***  adi,fagc-gain-increase-after-gain-lock-enable
  /* Fast AGC - Unlocking the Gain */
  0, //fagc_gain_index_type_after_exit_rx_mode ***  adi,fagc-gain-index-type-after-exit-rx-mode
  1, //fagc_use_last_lock_level_for_set_gain_en ***  adi,fagc-use-last-lock-level-for-set-gain-enable
  1, //fagc_rst_gla_stronger_sig_thresh_exceeded_en ***  adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable
  5, //fagc_optimized_gain_offset ***  adi,fagc-optimized-gain-offset
  10, //fagc_rst_gla_stronger_sig_thresh_above_ll ***  adi,fagc-rst-gla-stronger-sig-thresh-above-ll
  1, //fagc_rst_gla_engergy_lost_sig_thresh_exceeded_en ***  adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable
  1, //fagc_rst_gla_engergy_lost_goto_optim_gain_en ***  adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable
  10, //fagc_rst_gla_engergy_lost_sig_thresh_below_ll ***  adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll
  8, //fagc_energy_lost_stronger_sig_gain_lock_exit_cnt ***  adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt
  1, //fagc_rst_gla_large_adc_overload_en ***  adi,fagc-rst-gla-large-adc-overload-enable
  1, //fagc_rst_gla_large_lmt_overload_en ***  adi,fagc-rst-gla-large-lmt-overload-enable
  0, //fagc_rst_gla_en_agc_pulled_high_en ***  adi,fagc-rst-gla-en-agc-pulled-high-enable
  0, //fagc_rst_gla_if_en_agc_pulled_high_mode ***  adi,fagc-rst-gla-if-en-agc-pulled-high-mode
  64, //fagc_power_measurement_duration_in_state5 ***  adi,fagc-power-measurement-duration-in-state5
  /* RSSI Control */
  1, //rssi_delay *** adi,rssi-delay
  1000, //rssi_duration *** adi,rssi-duration
  3, //rssi_restart_mode *** adi,rssi-restart-mode
  0, //rssi_unit_is_rx_samples_enable *** adi,rssi-unit-is-rx-samples-enable
  1, //rssi_wait *** adi,rssi-wait
  /* Aux ADC Control */
  256, //aux_adc_decimation *** adi,aux-adc-decimation
  40000000UL, //aux_adc_rate *** adi,aux-adc-rate
  /* AuxDAC Control */
  1, //aux_dac_manual_mode_enable ***  adi,aux-dac-manual-mode-enable
  0, //aux_dac1_default_value_mV ***  adi,aux-dac1-default-value-mV
  0, //aux_dac1_active_in_rx_enable ***  adi,aux-dac1-active-in-rx-enable
  0, //aux_dac1_active_in_tx_enable ***  adi,aux-dac1-active-in-tx-enable
  0, //aux_dac1_active_in_alert_enable ***  adi,aux-dac1-active-in-alert-enable
  0, //aux_dac1_rx_delay_us ***  adi,aux-dac1-rx-delay-us
  0, //aux_dac1_tx_delay_us ***  adi,aux-dac1-tx-delay-us
  0, //aux_dac2_default_value_mV ***  adi,aux-dac2-default-value-mV
  0, //aux_dac2_active_in_rx_enable ***  adi,aux-dac2-active-in-rx-enable
  0, //aux_dac2_active_in_tx_enable ***  adi,aux-dac2-active-in-tx-enable
  0, //aux_dac2_active_in_alert_enable ***  adi,aux-dac2-active-in-alert-enable
  0, //aux_dac2_rx_delay_us ***  adi,aux-dac2-rx-delay-us
  0, //aux_dac2_tx_delay_us ***  adi,aux-dac2-tx-delay-us
  /* Temperature Sensor Control */
  256, //temp_sense_decimation *** adi,temp-sense-decimation
  1000, //temp_sense_measurement_interval_ms *** adi,temp-sense-measurement-interval-ms
  0xCE, //temp_sense_offset_signed *** adi,temp-sense-offset-signed
  1, //temp_sense_periodic_measurement_enable *** adi,temp-sense-periodic-measurement-enable
  /* Control Out Setup */
  0xFF, //ctrl_outs_enable_mask *** adi,ctrl-outs-enable-mask
  0, //ctrl_outs_index *** adi,ctrl-outs-index
  /* External LNA Control */
  0, //elna_settling_delay_ns *** adi,elna-settling-delay-ns
  0, //elna_gain_mdB *** adi,elna-gain-mdB
  0, //elna_bypass_loss_mdB *** adi,elna-bypass-loss-mdB
  0, //elna_rx1_gpo0_control_enable *** adi,elna-rx1-gpo0-control-enable
  0, //elna_rx2_gpo1_control_enable *** adi,elna-rx2-gpo1-control-enable
  0, //elna_gaintable_all_index_enable *** adi,elna-gaintable-all-index-enable
  /* Digital Interface Control */
  2, //digital_interface_tune_skip_mode *** adi,digital-interface-tune-skip-mode
  0, //digital_interface_tune_fir_disable *** adi,digital-interface-tune-fir-disable
  1, //pp_tx_swap_enable *** adi,pp-tx-swap-enable
  1, //pp_rx_swap_enable *** adi,pp-rx-swap-enable
  0, //tx_channel_swap_enable *** adi,tx-channel-swap-enable
  0, //rx_channel_swap_enable *** adi,rx-channel-swap-enable
  1, //rx_frame_pulse_mode_enable *** adi,rx-frame-pulse-mode-enable
  0, //two_t_two_r_timing_enable *** adi,2t2r-timing-enable
  0, //invert_data_bus_enable *** adi,invert-data-bus-enable
  0, //invert_data_clk_enable *** adi,invert-data-clk-enable
  0, //fdd_alt_word_order_enable *** adi,fdd-alt-word-order-enable
  0, //invert_rx_frame_enable *** adi,invert-rx-frame-enable
  0, //fdd_rx_rate_2tx_enable *** adi,fdd-rx-rate-2tx-enable
  0, //swap_ports_enable *** adi,swap-ports-enable
  1, //single_data_rate_enable *** adi,single-data-rate-enable
  0, //lvds_mode_enable *** adi,lvds-mode-enable
  0, //half_duplex_mode_enable *** adi,half-duplex-mode-enable
  0, //single_port_mode_enable *** adi,single-port-mode-enable
  0, //full_port_enable *** adi,full-port-enable
  0, //full_duplex_swap_bits_enable *** adi,full-duplex-swap-bits-enable
  0, //delay_rx_data *** adi,delay-rx-data
  0, //rx_data_clock_delay *** adi,rx-data-clock-delay
  4, //rx_data_delay *** adi,rx-data-delay
  7, //tx_fb_clock_delay *** adi,tx-fb-clock-delay
  0, //tx_data_delay *** adi,tx-data-delay
  150, //lvds_bias_mV *** adi,lvds-bias-mV
  0, //lvds_rx_onchip_termination_enable *** adi,lvds-rx-onchip-termination-enable
  0, //rx1rx2_phase_inversion_en *** adi,rx1-rx2-phase-inversion-enable
  0xFF, //lvds_invert1_control *** adi,lvds-invert1-control
  0x0F, //lvds_invert2_control *** adi,lvds-invert2-control
  /* GPO Control */
  0, //gpo0_inactive_state_high_enable *** adi,gpo0-inactive-state-high-enable
  0, //gpo1_inactive_state_high_enable *** adi,gpo1-inactive-state-high-enable
  0, //gpo2_inactive_state_high_enable *** adi,gpo2-inactive-state-high-enable
  0, //gpo3_inactive_state_high_enable *** adi,gpo3-inactive-state-high-enable
  0, //gpo0_slave_rx_enable *** adi,gpo0-slave-rx-enable
  0, //gpo0_slave_tx_enable *** adi,gpo0-slave-tx-enable
  0, //gpo1_slave_rx_enable *** adi,gpo1-slave-rx-enable
  0, //gpo1_slave_tx_enable *** adi,gpo1-slave-tx-enable
  0, //gpo2_slave_rx_enable *** adi,gpo2-slave-rx-enable
  0, //gpo2_slave_tx_enable *** adi,gpo2-slave-tx-enable
  0, //gpo3_slave_rx_enable *** adi,gpo3-slave-rx-enable
  0, //gpo3_slave_tx_enable *** adi,gpo3-slave-tx-enable
  0, //gpo0_rx_delay_us *** adi,gpo0-rx-delay-us
  0, //gpo0_tx_delay_us *** adi,gpo0-tx-delay-us
  0, //gpo1_rx_delay_us *** adi,gpo1-rx-delay-us
  0, //gpo1_tx_delay_us *** adi,gpo1-tx-delay-us
  0, //gpo2_rx_delay_us *** adi,gpo2-rx-delay-us
  0, //gpo2_tx_delay_us *** adi,gpo2-tx-delay-us
  0, //gpo3_rx_delay_us *** adi,gpo3-rx-delay-us
  0, //gpo3_tx_delay_us *** adi,gpo3-tx-delay-us
  /* Tx Monitor Control */
  37000, //low_high_gain_threshold_mdB *** adi,txmon-low-high-thresh
  0, //low_gain_dB *** adi,txmon-low-gain
  24, //high_gain_dB *** adi,txmon-high-gain
  0, //tx_mon_track_en *** adi,txmon-dc-tracking-enable
  0, //one_shot_mode_en *** adi,txmon-one-shot-mode-enable
  511, //tx_mon_delay *** adi,txmon-delay
  8192, //tx_mon_duration *** adi,txmon-duration
  2, //tx1_mon_front_end_gain *** adi,txmon-1-front-end-gain
  2, //tx2_mon_front_end_gain *** adi,txmon-2-front-end-gain
  48, //tx1_mon_lo_cm *** adi,txmon-1-lo-cm
  48, //tx2_mon_lo_cm *** adi,txmon-2-lo-cm
  /* GPIO definitions */
  -1, //gpio_resetb *** reset-gpios
  /* MCS Sync */
  -1, //gpio_sync *** sync-gpios
  -1, //gpio_cal_sw1 *** cal-sw1-gpios
  -1, //gpio_cal_sw2 *** cal-sw2-gpios
  /* External LO clocks */
  NULL, //(*ad9361_rfpll_ext_recalc_rate)()
  NULL, //(*ad9361_rfpll_ext_round_rate)()
  NULL //(*ad9361_rfpll_ext_set_rate)()
I have also tried the TDD mode (going into the RX state), but the issue persists.
Do you know what could be causing this? Could this be a hardware issue, and if so, what signals/power supplies should I pay closer attention to?
Thank you!
