BF537, NAPI Ethernet driver, out of order data
Question asked by sfe on Feb 26, 2016
Hello!
in an earlier Message to Sonic Zhang I described a problem I had with the NAPI ethernet driver on a BF537 CPU:
Hello Mr. Zhang,
currently I'm working on the ethernet driver for a custom Board with an Blackfin BF537 processor.
Kernel Version ist 3.10 off the uCLinux Branch (ADI-2013R1).
But we included the conversion to NAPI Patch from a later version (signed off by you, 2014-07-24).
In normal operations the driver works fine. But under very high load (the device is used in audio setups, and sometimes sombody unleashes a multichannel multicast stream on the wrong network) we see unexpected behaviour. The first sign where out of order packages in a ping request startet after the high load.
The situation is worsened by our main application that uses up ~50% of the CPU time.
Looking at the driver more closely it became obvious that the DMA pointers and the internal data pointer where not in sync anymore. So far my attempts to improve the situation failed.
Do you have any advice in that matter? What where your considerations regarding synchronisation when you switched to the NAPI model?
I found following paragraph in the ref manual of the BFin:
"Interrupt-based synchronization methods must avoid interrupt overrun, or the failure to invoke a DMA channel’s interrupt handler for every interrupt event due to excessive latency in processing of interrupts."
(page 5-55, Rev. 3.4)
which seem very relevant for this problem.
Any input from your side would be highly appreciated.
Sebastian Fett
Updates to that email are:
  • I switched back to a pre-NAPI driver in our application, and the problems disappeared. The impact of the IRQ load is very obvious in the device, but the data is received properly.
  • I wrote a small test (see code below. sorry for the hack). It sends 50 RAW ethernet packages as fast as possible from a PC. One of the data bytes is incremented. The same code can be compiled for the BFin, but then receives the data and checks the order of the data. With a application running in the background (30-50% CPU base load) I can replicate the out of order data easily with the NAPI driver. Without NAPI no out of order data happens.
the tool:
It's the same code for PC and BFin. For BFin you need to #define __BFIN_RX__ and use the bfin-linux-uclibc-gcc cross compiler. The PC version can be compiled normally.
The target MAC address is hard coded. The ehternet device can be set as a parameter ( ./testtool eth0). The default is eth0.
Possible Tool Output:
Using a RX buffer of 20 pakets I get the following result. The data is the incremented byte in the message and should be +1 in each step.
0
0x1
0x2
0x3
0x4
0x5
0x6
0x7
0x8
0x9
0xa
0xb
0xc
0xd
0xe
0xf
0x10
0x11
0x12
0x13
0x14
0x15
0x16
0x17
0x18
0x19
0x1a
0x1b
0x1c
OOO Data expected 0x1d is 0x31
0x31
0x1e
0x1f
0x20
0x21
0x22
0x23
0x24
0x25
0x26
0x27
0x28
0x29
0x2a
0x2b
0x2c
0x2d
0x2e
0x2f
0x30
OOO Data expected 0x31 is 0x10
0x10
Her you can see how 0x31 cames way early, practically changing places with 0x10.
Another result show more scrambling in the data:
0
0x1
0x2
0x3
0x4
0x5
0x6
0x7
0x8
0x9
0xa
0xb
0xc
0xd
0xe
0xf
0x10
0x11
0x12
0x13
0x14
0x15
0x16
OOO Data expected 0x17 is 0x2b
0x2b
OOO Data expected 0x18 is 0x2c
0x2c
OOO Data expected 0x19 is 0x2d
0x2d
OOO Data expected 0x1a is 0x2e
0x2e
OOO Data expected 0x1b is 0x2f
0x2f
OOO Data expected 0x1c is 0x30
0x30
0x31
0x1e
0x1f
0x20
0x21
0x22
0x23
0x24
0x25
0x26
0x27
0x28
0x29
0x2a
Regards
Sebastian
