Library Coefficients Not Initialized
Question asked by apope on Jun 29, 2011
Latest reply on Jun 30, 2011 by apope
Processor: 21371
VDSP: 5.0
Thanks for any help and enlightenment you can give.
I have had these calculations working before, but as the code has grown, the coefficients for some library functions are not initialized.  The sin function is one example.  How do I ensure these coefficients are initialized?
I am using the default ldf file modified for external sram.  Sorry for including so much, but I'm not sure what would be important.
#ifndef __NO_STD_LIB
SEARCH_DIR( $ADI_DSP/213xx/lib )
#endif
#define RT_LIB_NAME(n) lib ## n ## .dlb
#ifdef _ADI_THREADS
# define RT_LIB_NAME_MT(n) lib ## n ## mt.dlb
# ifdef __LIBIO_LITE
#  define RT_LIB_IO libio37x_litemt.dlb
# else
#  define RT_LIB_IO libio37xmt.dlb
# endif
#else
# define RT_LIB_NAME_MT(n) lib ## n ## .dlb
#  define RT_LIB_IO libio37x_lite.dlb
# else
#  define RT_LIB_IO libio37x.dlb
# endif
#endif
$LIBRARIES =
  RT_LIB_NAME_MT(c37x),
  RT_LIB_IO,
  RT_LIB_NAME(dsp37x),
#ifdef __ADI_LIBEH__
  RT_LIB_NAME_MT(cpp37xeh);
#else
  RT_LIB_NAME_MT(cpp37x);
#endif
// Libraries from the command line are included in COMMAND_LINE_OBJECTS.
#ifndef CRT_HDR
# define CRT_HDR 371_hdr.doj
#endif //CRT_HDR
$OBJECTS = CRT_HDR, $COMMAND_LINE_OBJECTS;
** List of objects which prefer internal memory placement
$OBJS_LIBS_INTERNAL =
   $OBJECTS{prefersMem("internal")},
   $LIBRARIES{prefersMem("internal")};
** List of objects which don't prefer external memory placement
$OBJS_LIBS_NOT_EXTERNAL =
   $OBJECTS{!prefersMem("external")},
   $LIBRARIES{!prefersMem("external")};
MEMORY
  seg_rth      { TYPE(PM RAM) START(0x00090000) END(0x000900FF) WIDTH(48) }
  seg_int_code { TYPE(PM RAM) START(0x00090100) END(0x00091554) WIDTH(48) }
  seg_pmco     { TYPE(PM RAM) START(0x000B0000) END(0x000B1554) WIDTH(48) }
#ifdef IDDE_ARGS
#define ARGV_START 0xb8000
  mem_argv { TYPE(DM RAM) START(0x000B8000) END(0x000B80FF) WIDTH(32) }
  seg_dmda { TYPE(DM RAM) START(0x000B8100) END(0x000B92FF) WIDTH(32) }
#else
  seg_pmda     { TYPE(PM RAM) START(0x000C1F80) END(0x000C1FFF) WIDTH(32) }
  seg_dmda { TYPE(DM RAM) START(0x000E0000) END(0x000E1FFF) WIDTH(32) }
#endif
  seg_stak  { TYPE(DM RAM) START(0x000C0000) END(0x000C1EFF) WIDTH(32) }
  seg_heap  { TYPE(DM RAM) START(0x000C1F00) END(0x000C1F7F) WIDTH(32) }
  seg_sdram { TYPE(PM RAM) START(0x00200000) END(0x00207FFF) WIDTH(16) }
  seg_sdram_pmda { TYPE(PM RAM) START(0x00208000) END(0x0020FFFF) WIDTH(16) }
  seg_sdram_dm { TYPE(PM RAM) START(0x00210000) END(0x002FFFFF) WIDTH(16) }
  seg_flash { TYPE(DM RAM) START(0x08000000) END(0x083FFFFF) WIDTH(8)  }
PROCESSOR p0
#ifdef IDDE_ARGS
    RESOLVE(___argv_string, ARGV_START)
#endif
    KEEP( _main,___lib_end_of_heap_descriptions )
    LINK_AGAINST( $COMMAND_LINE_LINK_AGAINST)
    OUTPUT( $COMMAND_LINE_OUTPUT_FILE )
    SECTIONS
        // .text output section
        seg_rth
            INPUT_SECTIONS( $OBJECTS(seg_rth) $LIBRARIES(seg_rth))
        } > seg_rth
        seg_int_code
            INPUT_SECTIONS( $OBJECTS(seg_int_code) $LIBRARIES(seg_int_code))
            INPUT_SECTIONS( $OBJECTS(seg_init) $LIBRARIES(seg_init))
            INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_pmco))
            INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_pmco))
            INPUT_SECTIONS( $OBJECTS(seg_pmco) $LIBRARIES(seg_pmco))
        } > seg_int_code
        seg_pmco
        } > seg_pmco
        seg_pmda
            INPUT_SECTIONS( $OBJECTS(seg_pmda) $LIBRARIES(seg_pmda))
        } > seg_pmda
        .bss ZERO_INIT
           INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(.bss))
           INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(.bss))
           INPUT_SECTIONS( $OBJECTS(.bss) $LIBRARIES(.bss))
        } > seg_dmda
        seg_dmda
            INPUT_SECTIONS( $OBJECTS(seg_int_data) $LIBRARIES(seg_int_data))
            INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_dmda))
            INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_dmda))
            INPUT_SECTIONS( $OBJECTS(seg_dmda) $LIBRARIES(seg_dmda))
        } > seg_dmda
        seg_dmda2
        } > seg_pmda
        seg_pmda2
        } > seg_dmda
        stackseg
            ldf_stack_space = .;
            ldf_stack_length = MEMORY_SIZEOF(seg_stak);
            ldf_stack_end = ldf_stack_space + ldf_stack_length;
        } > seg_stak
        heap
            ldf_heap_space = .;
            ldf_heap_length = MEMORY_SIZEOF(seg_heap);
            ldf_heap_end = ldf_heap_space + ldf_heap_length - 1;
        } > seg_heap
        seg_flash
            INPUT_SECTIONS($OBJECTS(seg_flash) $LIBRARIES(seg_flash))
        } > seg_flash
        seg_sdram
          INPUT_SECTIONS($OBJECTS(seg_sdram) $LIBRARIES(seg_sdram))
        } > seg_sdram
        seg_sdram_pmda
        } > seg_sdram_pmda
        seg_sdram_dm
        } > seg_sdram_dm
