AD9959: How to switch between different modulation modes
Question asked by aprilaries on Feb 18, 2016
Latest reply on Mar 3, 2016 by aprilaries
Hi, I am trying to use the AD9959's modulation mode to change its frequency, amplitude and phase. I also need to switch it back and forth between the single tone mode. I am using a FPGA to drive a AD9959 evaluation board.
Here is how I tried to implemented it:
1. write to channel registor 0x00, select 4-bit serial mode (set [2:1] to 11)
2. carry out standard single tone operations:
  write to CFTW0 (0x04)
  write to CPOW0 (0x05)
  write to ACR   (0x06) with [12] = 1
3. write to FR1(0x01) to set modulation parameters:
  change [14:12] to the right profile pin configuration
  change [9:8]   to the right modulation level, always use straight 16-level modulation, no any other extra such as RU/RD.
4. write to the profile registers (0x0A-0x18)
5. Write to CFR (0x03) to enable modulation:
  change [23:22] to one of the three modulation modes.
6. Switch the profile pin input to modulate the signal.
7. Write to CFR (0x03) to disable modulation([23:22] = 2'b0), back to the single tone mode.
All the bits not mentioned are in their default values.
For these steps, 1, 2, 3, 4 always worked by themselves with no problem. But once I changed the modulation mode and switch the profile pin, I couldn't switch the modulation mode any more, nor turn it off.
For example, after some single tone operations, I followed step 3, 4, 5, 6 to modulate the signal and everything worked fine, but when came to 7, the chip didn't change mode, and it simply stuck with whatever mode I had set in step 5. I could keep modulating it, but simply can't change or stop the modulation.
What do I miss here? Could anyone please give some suggestion? Thank you very much!
